MOTU 828mk3 Hybrid - Lowest Buffer Size
I have an ASUS G74 laptop, it has an intel 2670QM I7 - Win7 64. I have been using it as a general purpose PC replacement. When I am on a trip I will mix PT sessions with ASIO4ALL as the audio driver. I have been quite pleased with the performance.
I have thought about making it a dedicated mobile recording machine, but it only has USB 2.0 or 3.0 connections. I haven't used a USB interface in quite some time. Will a MOTU 828mk3 Hybrid handle recording 24 channels at low latency (64 buffer)? If anyone is using one in USB mode, Id love to hear. Dave
Re: MOTU 828mk3 Hybrid - Lowest Buffer Size
First of, the hard drive can be the biggest problem. If you have Pro Tools HD, it has a disk cache feature that can put everything in ram. You need lots of ram for this feature to work right. 8 gigs or more! Assign 4 gigs to the disk cache. If you record a whole set like over a half hour, that can be quite a challenge too. If you stop after a couple of songs that can be a little easier on the system. If you have an eSATA port and an eSATA caddy (Thermaltake makes the one I have) you'll be fine. Just buy your favorite desktop SATA drive and drop it in the caddy and you can record a lot.
I'm going to say no on the buffer. There is absolutely no need for that buffer size if you are recording live. I never use that in my studio desktop system and I never get complaints about delay or echo. I use 256 in general and its very tight. A buffer of 512 is quite usable but you may start noticing a slight ambient delay but not enough to through a musician out of time. I will say that Pro Tools is tighter in general. Cubase for example, reports a round trip latency. Your problem is USB 2 is just not going to give you that kind of latency unless you use RME hardware which uses the USB port in a proprietary manner. I have no idea if this works in Pro Tools. You need to describe your system a little more like you little profiles do. A Sandra report is the most complete way of informing every one what system you have. There's a link here on the forum. "Help us help you"! or something like that. |
You are better off running a higher buffer and using MOTU's CueMix FX monitoring software. It's simple to set up and very flexible.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
I use an old PCMCIA RME HDSP card on an old Core2 Duo laptop to run 24 channels of audio live at 64buffers, but the laptop cant handle any serious mixing. I was hoping to consolidate down to one portable rig to cover session mixing/tracking/live audio. Unfortunately I have found tracking down a laptop with a good CPU, capable of 16GB RAM, express card slot, 2 hard drive bays, and 1080 resolution monitor, driven by a Nvidia graphics card to be quite a chore. I picked up the ASUS laptop as I intended it to be a portable session mixing rig, so I was ok without the express card slot. But its been such a great DAW machine I was curios how far I could take it with a USB interface. Dave
Lowest PTHD H/W buffer size 256? | kevinb511 | Pro Tools TDM Systems (Mac) | 19 | 05-23-2011 01:06 PM |
What's the lowest H/W buffer size. | MultiCore | Pro Tools M-Powered (Win) | 4 | 05-16-2010 02:27 AM |
PT8 lowest buffer size windows XP | nekkio99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-26-2009 05:18 PM |
what's the lowest buffer size for 002? | reggie007 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-06-2003 01:56 AM |
ASIO, AM3 - Lowest Buffer Size? | Rock_Artist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-22-2002 04:38 AM |
