Old 03-14-2011, 01:44 PM
Deamhan Fola Deamhan Fola is offline
Default basic MBox Pro connection issues (newbie problem?)
Hi all,
I can't get any signals from my MBox Pro to find their way to PT 9 on my MacBook Pro. The details of my recording rig are in my signature. I downloaded the drivers for the MBox Pro as instructed. The MBox Pro is fine, or at least it's registering the mic input levels when I attempt to record vocals &/or guitar, but the signal isn't making it to the track. The instructions make it seem like I should just be able to plug everything in & go at this stage. Am I missing something? Do I need to do anything more than create an audio track in PT 9?
I am always sure to start up/ shut down in the order described in the manuals.
I have the rig hooked up in the following order: MacBook Pro--OWC external hard drive--MBox Pro.
HELP! Please explain any suggestions as if you were speaking to a 5 year old. (Actually, I'm a 40 year-old with a Ph.D. in the humanities, so, same thing these days.)
Mac Book Pro OSX 10.6.6, 2.8 GHz Intel Core i7, 7200 rpm, 8GB MHx DDR3
Mbox Pro
OWC Quad 7200 rpm, 2 TB
Old 03-14-2011, 10:26 PM
Benjamin_MFF Benjamin_MFF is offline
Default Re: basic MBox Pro connection issues (newbie problem?)
I have a similar problem. I am having trouble getting any output from the M box mini 3. I have updated pro tools and the m box mini 3 drivers are the most current. I have checked the wiring multiple times and everything seems to be in order, except the sound output. Any ideas?
Old 03-26-2011, 10:33 AM
lancemcv's Avatar
lancemcv lancemcv is offline
Try this, boot your mac, then turn on the Mbox then hold down the n key while launching pro tools, you should then be able to select the Mbox as your interface, pro tools may be defaulting to use your mac as the hardware instead of the Mbox. You can also look under hardware settings and make sure the Mbox is selected.
Old 03-27-2011, 05:40 PM
evilberg evilberg is offline
I have the new Mbox Pro hooked up with my Macbook Pro this way: MacBook Pro--MBox Pro--LaCie External Hd. I initially hooked it up like you are doing & got nowhere due to errors so I think you should try hooking your gear up like I do & see if that works better.
From the MBP into the MBoxPro & then out of the second fw slot on the mbox into the ext. hd
iMac 3.1 GHz i7 Quad Core, OSX 10.8.5, 16GB RAM, PT 10.3.9 & PT11
MBP 2.66GHz Intel Core i7, OSX 10.6.8, 8GB RAM, Pro Tools 10.3.9
www.einarvilberg.com
www.hljodverk.com
Mbox 2 Mini connection problem DTR1LL macOS 3 03-25-2013 09:28 PM
Mbox 2 connection issues bewareofdog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 24 05-10-2010 08:35 PM
Anyone using BX5a's and the Mbox? Connection issues?! toddamo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-06-2010 06:48 AM
Basic Connection question stringplay3` 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-15-2008 04:49 PM
Oxygen 8 v2 & Mbox 2, connection issues salcedodon MIDI 4 05-01-2006 01:56 PM
