Old 01-11-2011, 09:17 AM
m4tune m4tune is offline
Default PT 9.01 and Melodyne Editor 1.2
Seems that the automatic transfer path to the current project folder has gone with PT9.01.
Can´t get Melodyne Editor work in PT 9.01 for longer than 10sec of Audiotransfer - crashes allways my host during the Analysis…
Anybody can confirm this?
Mac Pro 5,1 12 Core 3,46 GHz MacOs 10.15.7 (Catalina/Dosdude), 64GB Ram, Angelbird Wings x2, PT HDX, HD I/O, 2x 192i/o, 1x Digi Pre, 1x Red8Pre 2x Avid S1. Artist Transport, PT2021.6
http://www.4tune.at
Old 01-12-2011, 09:31 AM
Hanswurstlsepp Hanswurstlsepp is offline
Default Re: PT 9.01 and Melodyne Editor 1.2
Works here perfectly with PT9.0.1. Did a lot of transfers and editing with Melodyne editor (the RTAS PlugIn) and had no problems - even with long passages.
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 01-12-2011, 04:14 PM
Epik Productions Epik Productions is offline
Hey,
We are having crazy melodyne errors to.
We currently use melodyne editor 1.1.5 and it crashes constantly.
We had that upgraded version and it was even more brutal.
Hanswurstlsepp - What version of melodyne are you running smoothly???
Even in PT8 melodyne refused to work properly and now in 9 its even more glitch.
Running a mac pro 8core 2.88 with 8 gb of ram on PT9 mac osx 10.6.5
Old 01-12-2011, 04:21 PM
Dism Dism is offline
Originally Posted by Epik Productions View Post
Hey,
1.1.8 works perfectly with 9.0.0 for me. Has been working fine since 8.0.1.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 01-12-2011, 04:24 PM
slater05 slater05 is offline
It's not the same situation, but my laptop has only 2 processors so melodye was a bit iffy most of the time, sometimes to the point where it would freeze mid transfer and not let me stop it, where I either had to do a hard reboot or let it go for ten minutes before it realizes it's supposed to stop.
But what really helped was in the preferences you can choose the option to wait u til the transfer is complete before it starts analyzing audio. I know it isn't a long term fix, but while on the clock it could be a quick fix that helps it stay way more stable.
www.mikeslatermusic.com
PTHD9 Certified Operator
15" MBP 10.7.2
Pro Tools 10.0
Apogee Duet
M-Audio BX5A's
Old 01-12-2011, 04:33 PM
hmm, ours has always been glitchy on playback and transfer.
We create melodyne projects and just import the vocal tracks and a mix minus from the original tracking session and sometimes have 4-8 tracks with melodyne on them. Even trying to playback just one at a time leads to constant crashes let alone multiple instantiations. Usualy it will just give the beachball of death and pro tools will quit.
Its quite frustrating for a program that is amazing at what it does.
Im having trouble finding any installer other than 1.2
the 1.2 is called "Melodyne singletrack" correct?
has anyone found that to be stable?
Now that we have 9 should we just upgrade to the 1.2 and see if its more stable?
Old 01-12-2011, 04:59 PM
Might as well give it a shot if yours isn't working. The new version is 64 bit and has some new workflow features. I've just been timid to upgrade because my current setup is working so flawlessly.
D
Old 01-12-2011, 07:48 PM
Im happy to say that 1.2 works pretty well with pro tools 9.0.0
it doesn't glitch as much, but it still does a huge beach-ball when closing a session with melodyne in it. It will eventually recover after about 5 mins but it does it every-time.
Old 03-27-2011, 10:53 AM
basslik's Avatar
basslik basslik is offline
How's every else doing with 1.2
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 03-28-2011, 06:15 AM
robo6675 robo6675 is offline
Default
1.2 has been very stable for me on PT9 and PTHD8 on a ppc. It's SO nice that you don't have to set your melodyne disk allocation manually any more! It is finally smart enough to write it in your plugin settings folder for the session.
I never let it try to analyze while transferring. That's just asking for a crash on a lot of systems...
There's a lot of annoying redraw bugs for me. Annoying but workable.
Anyone have weird issues with sessions that have tempo maps?
MacBook Pro (silver) 2.5 GHz Intel Core 2 Duo - 4 GB RAM - 10.6.6 - PT9 - 003 BLA sig mod
Terrarium
HD3 Accel on a PowerPC - OS 10.5.7 - PTHD 8.0cs2
(3)192/SYNC IO/CS HEDD192/Studer A27/Neve 48 Ch. VR console
Melodyne editor vs Melodyne plugin smpkeys Pro Tools 9 3 03-17-2011 12:33 AM
Melodyne 3.32 Editor 1.011 and PT8 tele27 Pro Tools TDM Systems (Mac) 7 03-19-2010 09:45 AM
Melodyne Editor on PT LE 8.0.1 Cloud_9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-17-2010 05:21 PM
Melodyne Users - Melodyne Editor Beta release imminent! Driven01 Pro Tools M-Powered (Mac) 2 09-18-2009 06:31 AM
Melodyne Users - Melodyne Editor Beta release imminent! Driven01 Pro Tools M-Powered (Win) 2 09-18-2009 12:15 AM
