Mbox 2 mini (monitoring always on)
I just got the Mbox 2 Mini with Pro Tools 9 but am having trouble figuring something out. When I plug in a microphone to the Mbox, I can hear everything that comes through the Microphone. It's like it is actively monitoring. Previously I had used an M-Audio MobilePre device which does the same, but had a control panel which would allow you to "Mute" the "Monitor Mix", so you wouldn't hear anything through the microphone until you recorded directly from the program.
The Mbox 2 mini does the same thing, but I can't find where to turn that constant monitoring off. Would anyone happen to know? What is the use of always having it monitoring whatever is coming in through the input? |
Re: Mbox 2 mini (monitoring always on)
Turn down the MIX knob.
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
Thanks TCM. Yesterday, I had read that that was how you were supposed to do it, but when I tried the input got louder. Probably because I had the Input 1 dial maxed when I turned the MIX knob off. I'll keep playing around with it.
Thanks. |
That should do it. . . was a bit confounding to me as well! :)
Mbox 2 Mini Monitoring Problems | walter gross | Pro Tools 9 | 6 | 03-17-2011 09:55 PM |
Mbox mini monitoring problems (maybe) | play4theworld | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-21-2010 06:57 AM |
Mbox 2 Mini Monitoring problem - HELP. | barismanco123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-14-2009 12:01 PM |
Apogee Mini Me - into Mbox .. help with monitoring | gteam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-25-2006 05:23 PM |
Mbox Mini-Me Monitoring Latency | Larue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-27-2004 06:50 PM |
