Does avi mbox 3 have low latency monitoring?
I use the mbox 2 with a really fast laptop 8gb of rams windowa 7 64 bit but i still have latency i have to mute the track to record... I will like to know if the mbox 3 have low latency monitoring... I will like to be able to do real time effects...
Do you thinks i will be able to do that with the new mbox? Thanks |
Re: Does avi mbox 3 have low latency monitoring?
So no one in here can answer this question? I am not buying the mbox untill i know...
just bought the new mbox today. it indeed has LLM.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64 Focusrite Saffire Pro 40 / Pro Tools 9.0.3 Mics, Guitars, Amps, Basses, Drums, Keys http://overtheeffect.bandcamp.com |
You could try lower your buffer setting with the Mbox 2 or using the Mix Knob.
Cheers,
zero latency monitoring for mbox 3 | kx4122 | FireWire & USB Audio Interfaces (Win) | 1 | 03-13-2014 02:18 AM |
Mbox 3 Low Latency Monitoring | charlesd81 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 02-25-2012 05:24 PM |
PT9 Mbox Pro 3 Low Latency Monitoring Bug | Glitch Magnet | Windows | 9 | 07-20-2011 05:47 PM |
Mbox 003 has Low Latency Monitoring? | Ormond | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-18-2010 09:16 AM |
low latency monitoring on PT LE 7.1 w/Mbox 2 ?? | MH2006 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-24-2006 03:16 AM |
