Old 09-12-2002, 04:16 PM
protooleo protooleo is offline
Default Re: OMS/AMT8/USB Extend It problems
I have the same setup. I have my USB exstended with the "geffen100" my computer sees my amt8 fine and I have the Digi Pre hooked up to it also, it all works fine. I am about 60 feet away from my computer. Sounds like OMS needs to be setup right.
Old 09-12-2002, 04:38 PM
Lee Blaske Lee Blaske is offline
Definitely, check the AMT8 out without the Extendit to establish that it's working OK.
This might not work in your case, but for some folks, it might be useful...
I've got some E4XT's and GigaStudio machines in my machine room. I have an AMT8 plugged in via USB directly to the computer in the machine room. Then, I use a serial cable (as Emagic recommends) to go from the first interface to the other three in my studio. In my case, the serial cable is 30', but I've heard of others going much farther (especially if you use quality wire). It's certainly a way to get some cable length on an AMT8 network without using any costly USB extension devices (an AMT8 from the discount retailers is probably cheaper than the Extendit, too).
DB9 connectors are fairly easy to make. Places like Markertek stock the Mini-DINs, but they're harder to work with. One solution for making long cables with Mini-DINs is to use a commercially made cable for the ends, splicing into it with high quality cable for the length of the runs. Use small shrink wrap for the individual connections, then a big piece of shrink wrap over the whole works. Pretty much anyone that's ever used a soldering iron and a heat gun can do it.
Lee Blaske
Old 09-13-2002, 12:00 AM
LKing LKing is offline
Default OMS/AMT8/USB Extend It problems
Has anyone had any problems with such a set up ???? Specifically OMS not seeing the AMT 8 ?? which is running through the extendIt.....
I have not had a chance to try the AMT8 without the "extend it" but will. Just wanted to know if anyone has had any experience with the setup (BTW it's on a Dual 1gig Quicksilver)
thanks
Lou
Unitor8 for 6.0, or just AMT8 & MT4??? MMazurek Pro Tools TDM Systems (Mac) 3 02-18-2003 09:26 AM
AMT8 SETUP...HELP PLEASE QXR987 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 09-11-2002 08:04 AM
HUI/AMT8/MIX DJBorrmann Pro Tools TDM Systems (Mac) 1 04-08-2002 12:02 AM
PTLE and AMT8 petter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-22-2002 03:56 PM
Emagic AMT8 Lydriket as Pro Tools TDM Systems (Mac) 7 06-03-2000 12:14 AM
