I\'m not hearing any play back, 96 i/o issues
hi
i've been fine, but this morning noticing that I push play on my control 24 and see the fades and everything moving and my speakers are on and fine (tested them with itunes) and I don't see any signals going up and down on the 96 i/o. i've restarted several times.... any thoughts? i've turned off the 96 several times too and the sync mode and input lights are solid and on... jeffery david |
Re: I\'m not hearing any play back, 96 i/o issues
Sorry for being a little bit off-topic, but I have found your nick name very interesting...
Sierota means "orphan" in my home language. Do you have any connections or ancestors from Poland... Drop me an e-mail; it is better not to put national discusses in here... Best from Warsaw Kuba |
yes my ancestors are polish jews...
jd |
jd |
Have you got the 96i/o meters set to outputs? or inputs monitoring?? this would explain the no signal on the 96. HW setup! on the c24 monitor section do you "pro tools sources" selected to monitor? Actually try re-setting the c24 in the utility section! then check above! Chris
Play back issues | Seihi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-09-2010 01:40 PM |
Hearing instruments in play mode??? | cneumeye | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-13-2008 07:48 PM |
Hearing instruments in play mode??? | cneumeye | Pro Tools TDM Systems (Mac) | 2 | 07-12-2008 11:53 AM |
I'm not hearing any play back, 96 i/o issues | JSIEROTA | Pro Tools TDM Systems (Mac) | 0 | 10-20-2006 08:41 AM |
