Direly need help - FW bus reset in Pro Tools 8 with 003
I posted this yesterday with absolutely NO response at all.
I'm beginning to think this is totally hopeless. I've tried everything I can think of - reinstalling software, switching cables, switching ports, etc. I can't get this thing to stop doing one of three things - -H/W buffer usually says it's underflowed and I need to increase buffer size -Pro Tools quits unexpectedly -And MOST often, there is a firewire bus reset I'm almost positive all these things are related to the same problem. Does anyone have ANY ideas? |
Re: Direly need help - FW bus reset in Pro Tools 8 with 003
You need to provide specifics of your OS, hardware, along with specifics of PT version and interface
Since this is an older setup it won't get as much attention as a newer setup, just the way it is.....however it was most likely caused by lack of useful and pertinent info about your setup We await your response
Sorry. I will add this now.
I'm running: Pro Tools 8.0.5 with a Digi 003 interface. It is running with Snow Leopard Version 10.6.8. It has an Intel QUAD Core (I'm pretty sure it is Quad, not Dual) Xeon Processor in it and 16 GB of RAM. |
I'm sorry and I'm running a Mac Pro. It really is a pretty high-end set up. The really PROSUMER setup of its time. Why I'm confused. :/
Is this a Mac Pro 3.1?
What are the hard drive specs, and by specs I mean format of connectors and cache size. Have you tried repairing permissions? Have you tried trashing preferences ?
pro tools click reset | adamcheese | Pro Tools 10 | 2 | 09-19-2012 07:16 PM |
Reset Pro Tools Memory? | acacia | Pro Tools TDM Systems (Mac) | 1 | 11-10-2010 08:19 PM |
pro tools has reset the sample rate of the hw device because it was changed by anothe | GHoSTFiNGeR | Tips & Tricks | 2 | 03-05-2010 10:13 AM |
Pro Tools region counter reset | marcnyc | Pro Tools TDM Systems (Mac) | 7 | 02-06-2010 07:23 AM |
003 rack reset when starting pro tools after being idle | jesseblu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-16-2008 10:52 AM |
