Old 05-29-2006, 04:14 PM
fman fman is offline
Default Replace region command in PT 7.1
Digi
Thanks for fixing the Hide Auto-created regions bug that was in PT 6.x
But now you've made the Replace Region command almost redundant! I use it to replace specific regions that has been pasted thousands times in a track - which in turn Auto-creates even more regions.
Previously i would turn off Auto-created regions, select the region i wish to replace in the edit window, and drag my replacement region from a very manageable Region List. Now, Replace region does not work unless Auto-created regions is on - making the region i'm selecting, and thousands of other regions from the edit window, visible in the Region List. This is annoying and totally interrupts my work flow as i have to scroll through thousands of regions before i can find the region i wish to use as a replacement (they all have the same name so using A-Z doesn't help either). Very fiddly. Its almost faster to just copy and paste.
Has anyone found a work around to this problem? Can it be fixed in a cs update. I would prefer to deal with the bug that was occurring in v6.x rather than lose this very handy command.
fman
Old 05-30-2006, 09:45 AM
DigiTechSupt's Avatar
Default Re: Replace region command in PT 7.1
I've logged this to have it looked at, though I doubt it will be addressed in a CS update, which are usually reserved to extremely critical fixes.
Avid Audio Tech Support
Support FAQ
Replace Region BUG naughty G Pro Tools TDM Systems (Mac) 1 05-13-2009 04:50 PM
Replace Region Command not working? noizgirl Pro Tools TDM Systems (Mac) 2 01-14-2008 08:04 PM
Replace Region command not working cloughri Pro Tools TDM Systems (Mac) 1 11-16-2006 04:33 PM
6.9 Mac Replace Region Bug?? Borg Pro Tools TDM Systems (Mac) 7 07-05-2005 08:17 PM
Region Replace webby Tips & Tricks 4 06-09-2005 09:44 PM
