General Questions about Mbox PRO
I recently purchased an MBOX pro for little money, I was A/B ing against a pod HD pro interface and proffered the clarity of the converters on the pod. I actually wonder if this down to the headphone amp as I use Sennheiser HD 650's?
The pod features a 600ohm headphone socket, where as the Mbox is much lower (I think).. So I'm not sure if it's the Mbox of the headphones?? Also for re-amping, I need to send a dry signal over S/pdif but the Mbox want's to be slaved for some reason? The Pod has no option to be set up as master. So I'm wondering what to do? |
Re: General Questions about Mbox PRO
Try setting the Mbox to be slaved via Spidf. I think it will work anyway. I got to try out a regular Mbox, which had the same requirement. I hooked up a DVD player via digital (just to use as a CD player). It has no clock controls, but it worked just fine.
Not sure about the headphone issue. When I tried the regular Mbox's headphone jack, it was the best I'd ever heard. |
An impedance mismatch A setting in the routing manager Or the converters aren't very good |
Buttdialed by me & Tapatalk
That's a real shame..
-Would never use headphone listening to evaluate anything other than the headphones -The converters on the are better than the HD Pro, you are probably hearing the effect of other factors you are adding. -mBoxes mirror the stereo output so no set up is needed to to the master other than matching the attributes of the 2 devices (bit and sample rate). -If the mBox wants to be slaved it's because was told digital
URBAN MUSIC- (Hip Hop and R&B) |
I don't get point 4? |
General Questions about Mbox PRO | MFire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-14-2013 07:02 AM |
HD & PT 9, and some general questions... | azulay | Pro Tools TDM Systems (Win) | 2 | 03-02-2011 09:24 AM |
General HD Questions | polar_electronics | Pro Tools TDM Systems (Mac) | 7 | 09-04-2008 10:25 PM |
From PC to Mac...general questions... | sethbrand | Pro Tools M-Powered (Mac) | 10 | 02-21-2007 02:07 PM |
General Mac questions | ratz | Tips & Tricks | 3 | 08-07-2001 02:40 PM |
