cant view WAV files once i edit them
Once I edit my wav files (add compression, bomb factory adjustments, and izotope editing) I can no longer view the file unless I zoom in 8 times.
I've tried restarting Protools LE 7.3, also the computer. Even started a new session and still blank wav files once I start to edit, unless I zoom in 8 times on that file, than it's viewable again. Any suggestions on how to fix this?? |
Re: cant view WAV files once i edit them
are you absolutely sure that your track view is set to waveforms????
"Sometimes having limits keeps you sane"- Albee1952 |
yes, i have it set for waveforms. i can only see the wav file when i zoom in * or more times ... just tried deleting the Volume .ddb and wavecache as well and got nothing
Have you tried making the waveforms larger instead of zoomiing in?
Did you "Recalculate Waveforms"? Cheers,
Yes, I've tried even fitting the waveforms to screen and they are still blank unless I zoom in about 8 times ...
recalculating the waveforms will bring the new edited selection of the audio up, but once i edited another selection of audio i must recalculate waveforms again for the visual of the sudio to pop back up |
found out my problem :)
I must have clicked the 'Recompute Invalid Overviews' off in the Prefrences Once I checked that back on, the wavs appeared again! Thanks everyone for the help! I highly appreciate it! -SnipeZ |
Track view in edit/mix windows | Ben Jenssen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-26-2009 05:06 PM |
Quick key for changing edit view to volume view in track? | postman56 | Pro Tools TDM Systems (Mac) | 4 | 11-30-2007 10:56 AM |
displaying tracks in edit view | LoudSound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-24-2007 06:28 PM |
Edit View Concern | Scroggs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-22-2004 10:26 AM |
edit view scroll | dmaxj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-11-2003 04:47 AM |
