Old 11-18-2010, 05:07 PM
Modern JJ Modern JJ is offline
Default Pro Tools 9 and Windows Vista
Hello everyone,
I wanted to know if their is any possibility to use Pro Tools 9 running windows Vista. I have a sweetwater creation station that is tweaked for peak performance with Windows Vista. If I install Windows 7 I take it that all goes away? Yikes!
Old 11-18-2010, 05:13 PM
justus1900 justus1900 is offline
Default Re: Pro Tools 9 and Windows Vista
I will bet you anything that it will work, you will not have any AVID Support but IM sure it will work, Someone on the Forum is running Pro Tools 9 on Windows XP. Windows 7 is built on the Vista Platform they are not that different. IM sure Pro Tools 9 will run better on Windoes 7 but IM sure it will work even tho I have never tried it, IM running Pro Tools 8 on Vista Business 32bit and Pro Tools 9 on Window 7 64bit just to make sure Pro Tools 9 is as stable as can be, Thank you
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell 5750 Precision Workstation
OS: Windows 11 Pro 64bit
CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz,
Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC
OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD
Focusrite Scarlett 18i20 3rd Gen
AVID Pro Tools 2023.12
JBL LSR4328P 8"
JBL LSR310S 10 inch Powered Studio Subwoofer*
Yamaha HS50M Studio Monitors
Alesis Elevate 3 Studio Monitors
M-Audio Axiom 61 Midi Controller
Old 11-23-2010, 10:50 AM
Well I tried and it said something to the effect that it couldn't install since vista was the current operating system? Any help?
Old 11-23-2010, 11:03 AM
necjamc necjamc is offline
I tried as well. The installer wouldn't run stating that I was on vista. I believe that you can upgrade vista to 7 without losing everyrthing provided its the same version ie 32 bit to 32bit prof to prof etc. Clone your system then try it. If it doesn't work install 7 ,and PT 9 on a new drive and just slowly install everything else. That's how I did it on my laptop that ran vista.
[IMG] code is Off
Windows Vista and Pro Tools Jon Oldroyd FireWire & USB Audio Interfaces (Win) 4 10-18-2013 01:34 PM
Windows Vista and Pro Tools 8 harlemrucker Tips & Tricks 7 02-27-2009 09:12 AM
Pro tools with windows vista bassman733 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 01-28-2009 11:03 AM
Pro Tools 7.4 and Windows Vista plasticine General Discussion 4 11-19-2007 03:29 PM
Pro Tools and Windows Vista M-ManLA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-23-2007 04:40 PM
