Want to upgrade my Mac...advice?
Currently I'm using:
MDD G4 DP 1.25 2G of RAM (my signature says 1 Gig, but I just upgraded) PTLE 7.1 Kontakt (guitar Rig 2, Battery 2, Elektric Piano, Absynth, Intakt, etc.) Gold Bundle I'm eating up way too much CPU power and am thinking of using my G4 to run the soft synths as a stand alone unit. I do a lot of vocal work and use the soft synths for drums, keys, and the occasional guitar track (guitar rig 2 sounds a lot better than my VG-8) Any thoughts on what Mac I shjould get; iMac-the 20-inch with 2 gigs of ram or the MacPro. The built in monitor aspect of the iMac is appealing, but I'm concerned I won't alleviate my CPU issues. Love to hear from anyone who really knows the scoop. Jace
Mac Pro 2.4 Quad, 8 Gig RAM Snow Leopard 10.6 HD Native PT 10 Omni Waves Platinum NI Komplete 8 API 512c, LA 610 Some Mics, Some guitars Some Songs |
Re: Want to upgrade my Mac...advice?
ker bump
I am in the same boat.
I need to build a second studio where I'd like to have one Mac, two hard synths, an 002 and loads of plugs to crank out various types of music. The main thing holding me back from IntelMac is my main axes from Spectrasonics aren't and wont be Intel ready for a while, but I hate to dump a lot of money into an older G5. In your case, I would definitley get the MacPro, so you could have all of your hard drives in one place.
International Award Winning Arabic Fusion www.ajmusiconline.com --------------- 2xMacPro 2.66,002r,OSX 10.4.10,PT 7.4cs8 3xVisionDaw,NI Komplete,Yamaha 01V/96 |
Wanna take some load off your G4 processors? check out a Waves APA unit to handle the processing of the plugs you use. (check out the used/demo page at sweetwater for deals.) It will free up some host power for yr VIs, and you'll be able to save some $ when you upgrade to a new mac.
I would just find another solution and move on until they catch up. |
So it does add power but only for certain plugs not all the Waves plugs. |
I would say check the plugs you need to see if they are available and if you will have to pay to upgrade them for the Intel. You have a tower so it's probably best to go with a new tower unless the funding is a real issue. One of the biggest reasons for the tower would be if you want to later try a UADe or Duende. You would require a slot in the tower for the installation of the UADe or for a FW card for the Duende. |
Thanks for all the insights fellas.
I definitely won't be gettin the Waves stand alone unit. It might be a good work around for some, but my G4 already handles the Gold bundle with no problems at all. It's the Native Instruments stuff that is kicking it's butt. Guitar Rig and Electrik Piano work great stand alone, but give fairly consistent hiccups when actually tracking. The tower argument is a good one, but then I also will need to buy an additional monitor. Thus making the tower cost about double the iMac. I will have to do an upgrade on the Gold Bundle, but the soft synths will continue to run on my G4 as a stand alone "synth" machine. The NI stuff all works standalone and doesn't seem to bog down the machine nearly as much when PT isn't running . Still, maybe I should get rid of the G4 all together and put the money towards a monster Mac Pro and continue to use one machine for all. Sorry to be so wishy washy, but I'm about to drop a lot of bread and want all the input I can get! Thanks to all posters.
The power of the new Macs is more than enough to merit not having to deal with trying to use 2 machines together. |
I'm leaning that way more and more. Thanks so much for your insights.
Any more from anyone is also apreciatted (i always spell that incorrectly).
Need Advice to upgrade to PT LE9 | [email protected] | Windows | 2 | 06-03-2011 02:19 PM |
Advice Please on LE to HD Upgrade... | pguy | Pro Tools TDM Systems (Mac) | 12 | 12-16-2009 09:10 PM |
Upgrade Advice | ralfddd | Pro Tools TDM Systems (Mac) | 1 | 09-14-2006 09:16 AM |
Advice: Mix to HD Upgrade | Mount Royal | Pro Tools TDM Systems (Mac) | 15 | 09-21-2005 07:11 AM |
Need Upgrade advice | DCatLDS | Tips & Tricks | 1 | 06-05-2003 09:08 PM |
