Old 10-31-2005, 09:15 PM
K-Man K-Man is offline
Default Audio spike problems with MBox 2...
Hey all,
I'm new to working with Pro Tools LE in Windows. I just hooked up my friends' MBox 2 into his P4 running XP (w/o SP1 or SP2). However, when you record enable an audio track, the "waveform" (if you will) just hovers up high, near clip, in the positive as though it was resting on the zero crossing. I've tried different cables, looked for feedback, different input devices like mics & keyboards... and found no resolution. So I'm here. Anyone encountered this before?
The specs we know of are as follows:
WinXP Pro
Intel P4 - 1.7GHz
1GB RAM
PT|LE 6.8.2
MBox 2
Thanks for your help!
-K
Apple Mac Pro 3.0 8C
8GB RAM
Digi002R
Dynaudio BM5a Monitors
Mac OS X 10.4.10
PT|LE 7.3.1cs4
CoreAudio 7
Old 10-31-2005, 09:23 PM
mix_master_adam mix_master_adam is offline
Default Re: Audio spike problems with MBox 2...
Which input do you have routed to the track that you are record enabling?
Old 11-01-2005, 05:37 AM
The Weed's Avatar
The Weed The Weed is offline
Try going into Preferences and unchecking "Draw Waveforms Rectified".
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 11-01-2005, 12:15 PM
Tried that too. Didn't work. I suspect it's either the AD converters or the Preamps. I've never seen that happen before, but I won't rule hardware failure out either. I just wanted to see if any of you on here have encountered the same problem.
Thanks!
-K
8GB RAM
Digi002R
Mac OS X 10.4.10
PT|LE 7.3.1cs4
CoreAudio 7
Old 11-01-2005, 01:15 PM
Oskee27 Oskee27 is offline
I tried running the MBox (the original) withouth SP1 and had problems. I installed SP1 and that fixed the problems I was experiencing which were basically recording problems. The recording session would cut after 20 seconds or so. Try installing SP1 at least on your XP system and see if that works.
Good luck
Old 11-01-2005, 01:40 PM
spkguitar's Avatar
The MBox 2 has only been tested and qualified on SP2. I would recommend upgrading the OS to SP2.
Both the mbox 2 and the mbox require at least SP1 to function because of the USB improvements in SP1.
Audio Spike Causes Reboot? Earl D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-28-2007 09:45 AM
problems with bounce to disk - extra noise spike? DJ FADE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-05-2007 01:56 PM
Mbox audio problems Jeff W. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-02-2007 02:50 PM
spike removal during post production (audio) carlacryptic Tips & Tricks 2 08-16-2004 11:14 PM
Audio problems with MBox binaural42 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-31-2004 12:45 PM
