Old 05-22-2013, 05:52 PM
EAPEntertainment CO EAPEntertainment CO is offline
Default Pro Tools 11 & Cubase
I was able to run both together on my iMac today.. I have my Steinberg MR 816csx running Cubase 7 & my Mod UR824 (Steinberg) running Protools 10... What I did was run Cubase into Protools using of course Adat & the analog outputs from the 816 into the UR824 & it ran flawlessly...
Will I be able to do the same with Protools 11?
Main DAW Presonus Studio One V3, Protools 12.4... Cubase Pro 8.5 & 8, Logic Pro X, Motif Rack XS, Waves, Slate Digital, & UAD, Blackface Apollo 8 (quad) 2 Apollo Twin Duo/Solo
Korg Kronos 61 & 73 key, Motif XF8, I-Mac I7 & Mac Mini, BLA Mod Steinberg UR824, Steinberg MR 816csx, Focusrite OctoPre,
Eric Allen
EAP-Entertainment Co
Old 05-22-2013, 05:54 PM
Default Re: Protools 11 & Cubase
The reason why I'm asking this is because I love using Protools to do all my mixing, it just works for me...
Eric Allen
Old 05-23-2013, 04:29 AM
The question is - what would you really gain from such a setup? I know you said you like mixing in PT and that's fair enough. Why not just do it all in PT instead then you wouldn't have to worry about anything like this.
Old 05-23-2013, 05:07 AM
Hey Musicman what's good bro...
The reason is I have some production already done in Cubase & also I have some clients who only work in Cubase & they use all midi base instruments so instead of doing the file transfer I just transfer using the Adat & outputs from the interfaces...
Eric Allen
Old 05-23-2013, 05:14 AM
apesong's Avatar
apesong apesong is offline
If you can do it now with Pro Tools 10 and Cubase, there probably isn't much reason why you wouldn't be able to with 11. Isn't it quicker and less work to just bounce the channels or stems and VST instruments out of Cubase and import the wav files into PT to mix though?
Old 05-23-2013, 05:36 AM
@ Apesong, yes it would only if i know how to do that... Honestly i'm not that savy with the software to know how to work it like that ... I wish I did though....
Eric Allen
Old 05-23-2013, 06:18 AM
DRC Music's Avatar
DRC Music DRC Music is offline
No stupid track count limits and the ability to use basically ANY plugin made
Pro Tools Ultimate 2023.6
Logic Pro 10.7.8
macOS Ventura 13.3
MacBook Pro (16-inch, 2021)
Apple M1 Max
Memory 64 GB
PreSonus Quantum 26x32 Thunderbolt
Old 05-23-2013, 06:44 AM
@DRC you are right about that & it's very easy for me also....
Eric Allen
Old 05-23-2013, 06:46 AM
Also ( and I hope this don't start anything) but mixing in Protools (To Me) sounds a whole lot better than mixing in Cubase (that's just to me & no pun intended)....
Eric Allen
Old 05-23-2013, 07:09 AM
DRC Music's Avatar
I 100% agree
Logic Pro 10.7.8
macOS Ventura 13.3
Apple M1 Max
Memory 64 GB
Use 003 with Pro Tools & Cubase - Lodo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-13-2009 06:45 AM
Pro Tools 8.0.1 and Cubase 4? si_the_music_guy Pro Tools TDM Systems (Mac) 5 09-18-2009 10:23 AM
Pro Tools -----> Cubase Sdesign Pro Tools TDM Systems (Mac) 3 11-30-2006 09:31 AM
from cubase to pro tools?? mbently 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-13-2004 02:42 AM
Pro Tools LE vs Cubase VST oasisman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-21-2002 01:33 AM
