Old 01-17-2021, 07:26 AM
akhafaji akhafaji is offline
Default Using Carbon with Avid Sync HD?
Hi
I have bought Carbon, great sounding and everything looks great.
the only issue I have now is using sync HD with protools to lower the tune and speed, I was using that sometime with singers and back vocal when they want to reach a high tone easier.
I'm using now varispeed to do that however it's easier via HD sync.
Is there anyway to use the HD sync with Carbon the same way it's been used with HDX/HDN to lower the speed/tune for the session?
Regards,
Ali
Old 01-18-2021, 12:03 AM
Default Re: Using Carbon with Avid Sync HD?
Originally Posted by akhafaji View Post
Hi
Regards,
Ali
Not possible unfortunately. The SYNC cannot be connected to Carbon (no DigiSerial port) and, whilst it can be used as a standalone device, the Variable Speed Offset is not accessible from the front panel (see page 35 of the manual).
https://lukehoward.com/
Avid Carbon Review in Recording Mag musicman691 Pro Tools | Carbon 5 12-06-2020 11:27 AM
AVID CARBON - the $3999 Eleven Rack replacement BCnSTL Eleven Rack 6 11-13-2020 09:33 AM
Avid Sync IO HDXSound Pro Tools 12 20 05-30-2017 04:53 AM
