Old 09-12-2017, 11:16 AM
85Flares 85Flares is offline
Default Re: Eucontrol v3.6.1 Now Avialable
EUCONTROL 3.6.1 CRASHING.
I've reinstalled
I've removed prefs
I've installed older versions.
I used to be able to at least get into the EUControl but now I've just got the wheel of doom.
HELP?
iMac 2013 intel
Sierra 10.12.6
Pro Tools 11
Artist Control (4 faders)
Old 09-12-2017, 11:56 AM
EddieJones's Avatar
Did you do this ? http://avid.force.com/pkb/articles/e...nstall-for-Mac
Old 09-12-2017, 12:57 PM
Just tried that as well, with a few different versions of the software. So far 3.6.1 opens and crashes immediately, and 3.3.2 has been slightly stable, even with the clean installs. I've actually gotten to the 'add surface' a few times, and then when I go to 'update firmware' i get the "unable to connect to the unit named MC Control."
Honestly. it's pretty bizarre how unstable these euphonic programs have been today. I can't really believe it. Am I missing something? My PT system runs flawless w/ apollo twin and an extra 8 from UA 4-710D with optical.
Most of them opened and were immediately unresponsive.
sigh.
Old 09-12-2017, 01:27 PM
EddieJones's Avatar
I think if you look at other posts the latest EuControl releases are pretty stable. I would look at your network and how that is configured and connected. Can you let me know how it is setup ?
I would check/change out your Ethernet cables first.
Old 09-12-2017, 01:48 PM
I don't think it's the ethernet cable because that's been my cable from the computer to the wall for some time now, and it's working great.
I'm aware that some people are finding it stable, but I'm just saying that it's solid beachballs on my system. All day. It's really been weird. My network wouldn't be the reason for EuControl to be crashing all day would it?
I really appreciate the help here. and would love to get the artist control up and running, but their software just really doesn't like my computer.
  #16
Old 09-12-2017, 02:06 PM
EddieJones's Avatar
Totally and is usually the reason. EuControl is in constant communication over the network and if there's a problem (delays, missed messages) this causes hangs.
  #17
Old 09-12-2017, 04:32 PM
Two different ethernet cables.
Made the connection static.
Tried four different versions of EuControl.
Restarted my computer.
Clean installed.
I can see that the ethernet connection to the artist control is green.
If my network is the issue, than please instruct on what I could possibly do next?
It seems rather odd to design something that opens itself, and then crashes if it can't connect to the hardware? I dunno, maybe it's something on my mac. Maybe it's the hardware itself. I bought from Amazon, but through a used vendor. Might have to send it on back, and try something else.
Thanks for your time today.
  #18
Old 09-12-2017, 07:56 PM
EddieJones's Avatar
Are you connecting directly 1:1 or through a router ?
  #19
Old 09-13-2017, 11:55 AM
He Eddie! I'm connecting 1:1. At this point I've got it boxed up and have the white flag out, walking sadly back towards my mouse.
Curious if there's a way to test the controller itself?
  #20
Old 09-14-2017, 09:33 AM
EddieJones's Avatar
There's no way to test the controller's connection, unfortunately. When you say you set it to fixed IP, this was both in the Mix and the Workstation right? Also when bouncing between software versions like you're doing it's very important to do the clean EUCON each time.
I think the next test would be to try on a different computer and if that doesn't work assume you have a bad unit.
What does EuControl W/S do? maunaloa Avid S1, S3, Dock and Control App 10 06-19-2019 06:35 AM
Eucontrol v3.6.1 Now Avialable EddieJones Artist Series 5 07-22-2017 12:43 AM
EuControl 3.4 mbryan67 Avid S1, S3, Dock and Control App 5 05-27-2016 02:23 PM
EuControl Trazan Artist Series 3 12-13-2011 12:57 PM
Eucontrol 2.6.2 out robertg Artist Series 22 11-07-2011 12:11 PM
