Problem with TL Space ...
Hi everyone,
the TL Space is my first choice reverb ...but i use to use the reverb on True Stereo format and i can use it only on Long format ...on Medium format, the True Stereo doesn't fonction right. If you try to send a track to the reverb, with the send panned hard right ...there is no reverb signal. About Short format, i use to not use it because of its latency. In final, it's a problem because a True Stereo Long reverb take 4 DSP Accel chip and i don't need Long reverb everytime, specially for room reverb ! I think it's a bug ...but i don't know who gonna fix it, digidesign ? Is there anyone who is in the same trouble ? Regards, Julien A. |
Re: Problem with TL Space ...
any answer ?
I am feeling so lonely ! |
Have you tried RTAS version? whats that doing?? Chris
What version of the plug-in are you running?
sorry for the lateness ... The TL Space version is V.1.1.3r5 The Protools version is 7.2 The Mac OS version is 10.4.6 I don't use the RTAS version because of its latency (480 samples), same thing for the Short version (1029 samples). Regards, Julien A. |
just tried the same thing and yes Medium True Stereo has no reverb when send is panned hard right
ripped off!!! TL space 1.1.3.4 7.2 10.4.6 G5 2.5 |
Is there someone to help us ?
Any Trillium Lab member or Digidesign menber ? Regards, Julien A. P.s. : what is the futur of the Trillium Lab products ? Does Digidesign continue to work on them for updates ? |
Hi, I'm also having trouble with TL Space TDM. If I use Snapshot Automation I get a DAE -6042 Error. I know this from the first days of using TL Space, but it was fixed in a later PT 6.9 Version.
Now we moved to PT 7.2cs1 and got this Error again. Anyone else??? Also TL Labs wasn't aquired by Digi these early days, we had a direct contact to a Programmer from TL Labs and he worked very quick on a Fix. I'll send my Problem to Digi today and hope that they fix it asap too. |
I had an engineer report today that when he attempted to use TL Space True Stereo (whatever that is) Long that it wouldn't load. Pro Tools started a plug-in shuffle. It shuffled, and shuffled, and shuffled...and ultimately gave up (-7204). I checked the system usage window, and I can assure you there was PLENTY of DSP available. Anyone else ever see this?
Problem loading TL Space | zfs | Windows | 1 | 03-20-2013 07:03 AM |
TL Space problem | Badlands | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-22-2009 10:57 AM |
tl space problem | abrigueiro | Pro Tools TDM Systems (Win) | 0 | 07-05-2008 03:31 PM |
TL Space problem | mrsystem | Pro Tools TDM Systems (Win) | 28 | 10-22-2007 02:58 AM |
space bar problem | bentley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-10-2000 12:28 AM |
