Old 03-09-2020, 02:58 PM
aaronbagby aaronbagby is offline
Default Dumb. question...bouncing stems/tracks
OK. I have been confused. on this for my entire time as a PT user. I need to send a bounce of a single track to a friend.
If I solo the track and then do a bounce, it ignores my solo selection. All tracks heard. Everything is fed through auxes that feeds a mix bus. Mix bus is the only thing that hits main outputs. Nothing is solo safe'd, my bounce source is set to physical output 1-2. Still, every track is included in the bounce. Google results say that solos should be reflected if the bounce source is set to physical outs. This is killing me!
Old 03-09-2020, 03:03 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Dumb. question...bouncing stems/tracks
Sounds weird..
Anyway, let's start with some information of your setup. Please take a look at the Help Us Help You linked to the forum header.
Janne
Old 03-09-2020, 03:28 PM
Ok. System specs:
mid 2018 MacBook pro
OSX Mojave 10.14.6
i9 2.9ghz
32GB. Ram
PT 2019.12.0
I think maybe my understanding of soloing in PT is just doomed. I really need to figure this out. I want it to be such that if I solo an aux, I hear all tracks sent to the aux. If I solo a track, I want to hear that track routed all the way to the mix bus. Search results claim that I should solo safe auxes. I've done this, which allows me to hear bus processing on tracks if I solo at track level, but then soloing that aux just mutes all sound. Search results say "then solo-safe the tracks feeding the bus also". But then those tracks don't mute when I solo an unrelated aux. I cannot wrap my head around this, and I've watched enough videos to make my head spin.
Old 03-09-2020, 06:56 PM
kcfroines kcfroines is offline
How about muting the auxes/ tracks you don't want to play instead? or make them inactive?
Trying to solo on an aux isn't recommended
Old 03-09-2020, 07:19 PM
JFreak's Avatar
If nothing else helps and there indeed is a bug, after reporting the bug to Avid Support, route your soloed track/buss to a dummy buss like Bus 127-128 and bounce that buss.
Janne
Old 03-09-2020, 08:42 PM
Forgive me but I just don’t get that logic in the least. Why would soloing an aux be undesired? If I decide i want to hear my drums/bass together to lock in the rhythm section, I definitely don’t feel like muting 40 other tracks, or even 10 auxes, when I could as easily solo two.
Old 03-09-2020, 09:37 PM
smurfyou smurfyou is offline
Try setting up VCA's for each group. Use the VCA Master to solo the members.
~Will
Old 03-09-2020, 10:35 PM
I'm not saying it's undesired. I'm just saying how it works in Protools. When you solo a track it mutes everything that isn't also solo'd or solo-safed.
If your sessions aren't setup so you can mute a few auxes setup some vca's
Old 03-10-2020, 01:46 AM
Wolfgang Eller Wolfgang Eller is offline
Are you using SIP?
www.srs-mastering.de
Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface.
Old 03-10-2020, 02:46 PM
Maybe a clearer explanation of the goal would help?? If its a single track you want to share, don't bounce it...use Track Commit. Then export that new audio file
Bouncing Stems TheDavidLim Pro Tools 12 15 04-22-2017 11:36 AM
Dumb Question about Instrument Tracks Extramission MIDI 4 05-06-2009 02:01 PM
Dumb Group Tracks Question tomhartman Pro Tools TDM Systems (Mac) 3 12-28-2003 11:02 PM
Dumb Question about bouncing wolfi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-12-2002 08:44 AM
Dumb question: JV-2080 mono and stereo outs yield identical PTLE tracks? el biciclista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-04-2001 12:45 AM
