Old 10-23-2018, 12:02 PM
yl956 yl956 is offline
Default buffer size 48 samples
when tracking in fl studio i can you use a buffer size of 48 samples in pt 2018 the only low options i have are 64 and 32 as a buffer size is that the standard for protools? if so i was looking to purchase a new audio interface any suggestions on some that can run as low as 32 samples?
Old 10-23-2018, 03:11 PM
Default Re: buffer size 48 samples
You are leaving off any useful info about the interface needs?
What inputs/outputs?
Computer/OS?
interface connection? USB2? Thunderbolt 3?...
Budget?
What buffer size works in practice is very much dependent on your computer.
Can you use (effectively) zero latency hardware monitoring? If so that a key feature to look for, and skip the fight for low buffer size. And if you want to monitor through plugins then there is UAD Apollo, and Now getting started Apogee.
Old 10-23-2018, 03:16 PM
The Weed's Avatar
The Weed The Weed is offline
Pro Tools only allows multiples of 32: 32, 64, 128 etc.
You have a Babyface Pro and it allows different buffer sizes, but PT doesn't.
Also, IIRC, PT only does 32 on Mac and only goes down to 64 on Windows.
You have a great interface in the RME BFP and it has great drivers, so no need to look for another interface.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
help using 48 samples (buffer size) yl956 Pro Tools 12 4 06-15-2018 08:28 AM
HW buffer size 64 samples..?.. Codo Pro Tools TDM Systems (Mac) 2 11-01-2011 03:58 PM
32 Samples H/W Buffer Size playback with 192 I/O MikeLip Pro Tools HDX & HD Native Systems (Win) 16 09-10-2011 12:36 PM
can't change h/w buffer size above 128 samples mmiller Pro Tools M-Powered (Win) 6 07-24-2010 10:42 AM
My whole system crash when i set my H/W Buffer Size @ 128 Samples or less rogerhavoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-29-2002 02:50 AM
