latency when recording
when im recording im not getting any latency its when i finish recording and i playback my take and its a bit off...in fl studio i dont have this problem...ive tried delay compensation but its useless...i have basic eq compresser n auto tune when im recording...with a buffer size of 64 any ideas on what it could be?
Re: latency when recording
No idea without lots more info on your system. Help Us Help You
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
and what is the expected latency of auto tube how you have it running?
Yes, how much latency is introduced for each plugin? On a related note - why are you recording with Autotune on the track? Not saying it's wrong to do so, but it isn't often the best way of using Autotune.
Again not a lot of useful info.
What version of Auto Tune? Latest stuff? How is it being used? ... Autotune can have horrendous latency. What is the expected latency for how it's being used... see the documentation. What is the ADC latency reported by Pro Tools? As Chris points out lots of folks would not record though Auto Tune. There are probably lots of ways to skin this cat, e.g. you can try dual track (record same input to another track) totally dry. Hopefully that one is time aligned correctly. Then just use that at mix time. Autotune may be reporting latency wrong to Pro Tools. Lots of troubleshooting could be one here, measuring the exact latency, etc. dows it work OK without the compressor? Without auto Tune? but how much time is with it is worth you to experiment with that. Who knows. Again details... what exact compressor? What's the expected latency of that plugin? |
If you legitimately own Autotune, you’d have the AAX version. They don’t sell licenses for the different formats individually. Sent from my iPhone using Tapatalk |
Go to View>Mix Window>check the Delay Compensation option. That opens a row across the bottom of the MIX window that shows plugin latency
The first problem here is bluecat, get that layer of complexity out of there. Who knows how well latency for this plugin is reported via all that ball of string. There is no reason to be using that here. That you have all this crap configured like this is the sort of useful information that should have been provided in your first post describing what you are doing. Waves API 2500 compressor is zero latency, so not even an ADC issue there, but still remove it while troubleshooting. Remove everything, get a new empty session and add AAX AutoTune and see how that behaves. You coudl have exra problem in the current session with say more complex routing/bussing. If the new session misbehaves then start measuring latency, ADC reported latency, etc. Then how are you using AutoTune? What version is it? Low latency mode? etc. what is the expected latency of that plugin... |
Recording Latency, (Have to shift regions after recording) | brucefielder | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-05-2011 04:21 PM |
low latency recording vs low hardware buffer size recording | chrisdee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 01-27-2009 06:49 AM |
Too much latency in recording | Bernardo Sanoja | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-16-2005 12:29 AM |
recording and latency | Ricco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-25-2002 08:25 PM |
Whats the difference between Low Latency recording and recording on low latency with | Dead River Studio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-25-2002 01:22 PM |
