Old 12-25-2011, 12:55 PM
ProMac07 ProMac07 is offline
Default Which Mac Mini: 2.7 GHz Dual-Core or 2.0 GHz Quad-Core???
Hey everyone. I'm going to be buying a new computer soon to run Pro Tools on. I decided to get a Mac Mini for now with 8GB of Ram and with a SSD. I'm just trying to figure out which Mac Mini should I be getting?
2.7 GHz Dual-Core i7 or 2.0 GHz Quad-Core i7 (Server)
I'm doing Hip Hop/R&B production and probably won't be using too many tracks. As for plug-ins I still don't know how many I'll be using yet.
Which one will be more beneficial to me? I know that the 2.7 GHz dual-core has more power but less cores than the 2.0 GHz quad-core model.
Does Pro Tools benefit from having more cores?
(I read on this site that unless your doing multitasking you don't really need multi-cores.)
http://angelaharris.hubpages.com/hub...ors-Comparison
Thanks, Jay
Old 12-25-2011, 02:44 PM
CME CME is offline
Default
Pro tools is multi-threaded so I'm pretty sure the quad-core server would be the way to go. It also includes 2 hard drives out of the box. Another plus.
And just my .02 but I'd upgrade the RAM and SSD myself. It will save you a good deal of money. Also the new minis can run up to 16gb of ram. Not the 8gb apple says. However there is a big jump in price between 8gb and 16gb. By still something to consider.
2009 Mac Pro - Dual X5650 Xeon 6-core 2.66Ghz procs, 48GB of Ram, SATA 3 and USB 3.0 PCIe cards. R9 280X video card. macOS Sierra. Harrison Mixbus 32C, Studio One 3, Reaper, and pro tools 12 when I have to.
Old 12-25-2011, 02:49 PM
jryser's Avatar
jryser jryser is offline
Default
I just paid 349 for 16 GB. Well worth the upgrade!
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
Old 12-25-2011, 07:04 PM
Default Re: Which Mac Mini: 2.7 GHz Dual-Core or 2.0 GHz Quad-Core???
Cool, so I would benefit from the quad-core. I read somewhere on these forums that:
4 x 2.0GHz = 8
2 x 2.7GHz = 5.4
Is this true?
Yeah, I'm upgrading the RAM myself, from macsales.com, with 8gb going for $49.99. Apple charges way too much. So u can run 16gb of ram, cool.
As for the hard drives, I didn't know you can upgrade that as well on a Mac Mini, but that's what I'm gonna do now. Is it better to have an internal Solid State Drive or externally, do u know?
Also, what do u think about running Pro Tools on a Mac Mini, will it be able to keep up?
Old 12-25-2011, 09:32 PM
CME CME is offline
Default
Not sure about the first part of your post but maybe you're referring to hyper threading??? If so yes pro tools will see 4-processors in the dual core i7 mini and 8-cores in the quad.
Yes you can upgrade the hd. Don't remember what sites but there's instructions and how to's out there. It does require a bit of disassembly if memory serves though. And I'd personally go with a ssd internal for the os and apps and have a second internal drive to record to. But keep it a 7200 rpm standard drive.
As far as performance goes, for most people it should be plenty. But you can push any system to its limits if you want to. Really a lot of VI's and amp modeler plugs are the most taxing. I don't use those very often but something to consider. My 2.6 ghz c2d MacBook Pro is still plenty for me. And the quad-core mini is probably 3-4x more powerful.
Old 12-26-2011, 08:42 AM
Yeah I guess I meant multi-threading.
Wait so you use the Solid State Drive for the OS and apps? I thought that was gonna be used for recording?
Also the quad-core brings 2 hard drives (both 7200rpm), so are you saying to take one out, install the SSD and just leave the other 7200rpm Hd there?
Old 12-26-2011, 09:44 AM
Also the quad-core brings 2 hard drives (both 7400rpm), so are you saying to take one out, install the SSD and just leave the other 7400rpm Hd there?
In most cases, the SSD will help the OS more (faster OS startup, faster application loading, etc.) than the recording drive. This is because the recording process is a sequential writing process and SSD's strength is reading speeds (not writing speeds). SSD's have improved their writing speeds with each new generation so things are getting better. Some folks have had good success recording to an SSD but some have not. Spinning discs are still the media of choice for recording for now.
Please note that the Mac Mini server in it's unchanged configuration comes with 2 5400RPM drives. To get the 2 7200RPM drives is an extra cost option. Also the server comes with Lion Server for the OS. This puts quite a lot of unnecessary applications and services on the OS that may negatively affect the way Protools works. You may consider formatting and loading the regular Lion OS.
Obsidian Dragon
Model Name: MacBook Pro
Model Identifier: MacBookPro14,3
Processor Name: Intel Core i7
Processor Speed: 3.1 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 16 GB
MacOS 10.13.6 running Protools 2018.7.0
Old 12-26-2011, 10:23 AM
tekis tekis is offline
Got a MMS! Came stock w/ dual 7200rpm drives. Digging it!
2009 Mac Pro 12-core 3.33 Westmere , OS 10.12.6, 64 gig of ram, SSD system drive, PT Ultimate 2019.6 HD Native; 2015 MacBook Air, OS 10.14.6, i7, 8gb ram, SSD, PT Ultimate 2019.5
_____________________________________________
Some credits:
http://www.allmusic.com/artist/john-...s/date-asc/100
http://soundbetter.com/profiles/3845-john-siket
Old 12-26-2011, 11:23 AM
Talking Re: Which Mac Mini: 2.7 GHz Dual-Core or 2.0 GHz Quad-Core???
So I see. Cool, I guess I'll be using the SSD for the OS, apps and stuff.
Good to hear tekis! Can u give me any feedback.
Obisidian Dragon, the new server models now come with dual 7200rmp drives like Tekis said, go to apple and check it out.
Yeah that's the other thing I was wondering what's so different about the Server model?
I was reading this thread and I'm worrying about any problems I might run into:
http://duc.avid.com/showthread.php?t=307472
Old 12-26-2011, 01:20 PM
It's all been said in that thread. I got 8 gb ram from OWC. I thought about the ssd but haven't seemed to need it so far. Presently, they're expensive...
Some credits:
[IMG] code is Off
Apple Mac Mini Core i7 2GHz QUAD CORE - 4GB RAM - 2 x 500GB gsilbers Buy & Sell 3 05-18-2013 05:17 PM
Mac Pro Dual Quad core compatable with HD pci core & accell cards? PT8716 Pro Tools TDM Systems (Mac) 3 06-28-2010 07:35 AM
Quad Core / Dual Core / Nvidia or not / I'm lost... AndyJCP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-09-2009 02:44 PM
Mac Pro Quad 3.0ghz 4 core vs. Dual Quad 8 core? AllThingsMusicStudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-04-2008 08:22 AM
Single core vs. dual core vs. quad core John Peeples Tips & Tricks 9 11-07-2007 03:28 PM
