Upgraded to PT 12.5 now automation buttons not working
Is anyone else experiencing this?
All worked fine in 12.4, upgraded to 12.5 and now pressing 'Sel' and an automation mode now has no affect, any ideas? |
Re: Upgraded to PT 12.5 now automation buttons not working
works fine here, i.e. as fine as before the upgrade.
One thing that happens a lot and has happened a lot (always?) before the update as well: - when you change the automation mode twice in a row on the same single channel/set of channels the second time it doesn't work any more. E.g. put track 1 in trim mode by pressing the trim and see buttons works fine. Then try to put it out of trim mode the same way: it doesn't work, I first have to select another channel before I can do this. Quite buggy.... |
thanks yoerik for checking, what a numpty complete user error on my part (been away from the studio for a little time), for some reason I wanted to press sel first, when in fact automation mode first then track select.
I checked what you are experiencing with automation mode sort of sticking and its the same on my system, first time it changes, next and subsequent times seems to be a bit iffy, sometimes it changes, other times it doesn't |
Hi BM, thanks for checking as well. Did you get the Eucon 3.4 upgrade yet? It's less iffy on my S3 now, although most of the time you have to double tap the sel button the second/third/... time you change the automation mode on the same channel. Could you check if that's the case for you as well after upgrading to Eucon 3.4?
I've put in in this thread:http://duc.avid.com/showthread.php?t=381330 |
Map Automation Page functions to physical buttons or key commands? | alexeymohr | Pro Tools 11 | 6 | 09-18-2014 08:30 AM |
PT10 - transport buttons not working | Led | Artist Series | 2 | 06-20-2013 02:35 PM |
No Record buttons working since d/l 9.06 | Tedly | macOS | 0 | 12-10-2011 12:28 PM |
MBOX Pro Buttons Not Working | BOSSHOG | Pro Tools M-Powered (Win) | 0 | 11-15-2011 11:13 AM |
Bypsss buttons not working in 6.41 | TuT | Pro Tools TDM Systems (Mac) | 0 | 11-08-2004 04:17 PM |
