Old 07-21-2009, 04:41 AM
yanncrusoe yanncrusoe is offline
Default How to change sample rate?
Ive recently realized my sample rate is at 48khz which has been causing problems with BFD2. I cant seem to work out how to change it to 44.1
can anyone help?
thanx alot.
MBP 17" 2.4 ghz, 320gb 7200 , 4 GB RAM, Glyph GT050Q, 10.5.7
Mbox2, PT8cs3, BFD2
www.myspace.com/yanncrusoe
Old 07-21-2009, 05:25 AM
tamasdragon tamasdragon is offline
Default Re: How to change sample rate?
When you make a new session, there is session preferences. You can set it there.
Tamas Dragon
my blog:Tamas Dragon
Old 07-21-2009, 06:53 AM
Thanx but i cant find that.
Can you not change the sample rate in an existing project?
Mbox2, PT8cs3, BFD2
Old 07-21-2009, 07:14 AM
Oddbod Oddbod is offline
Go: File > Save As...
Save the session as a copy. You need to select the option to copy the audio files. Set the sample rate of the new session to a different rate than the original. It will then do the sample rate conversion while copying the audio files.
O-B
Old 07-21-2009, 07:24 AM
thanx alot!
Mbox2, PT8cs3, BFD2
Old 07-21-2009, 11:04 AM
You are welcome
O-B
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! Nickford Windows 0 05-26-2013 12:20 PM
Can't change sample rate Gabriel_S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-20-2012 12:43 PM
Can't Change Sample Rate jasonschwartz Pro Tools M-Powered (Win) 1 01-12-2007 12:13 AM
how to change sample rate?? remains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-28-2002 05:38 PM
Change Sample Rate in HD? Steven Sena Tips & Tricks 2 08-10-2002 07:33 PM
