Old 11-10-2005, 04:05 PM
Howardk Howardk is offline
Default Re: McDSP Analog Channel or Cranesong Phoenix?
I forgot about the DUY analog stuff, those plugs do sound great
I am interested in DUY. Which particular plugin are you liking and what kind of results are you getting? I am often looking for something more agreesive than Phoenix, but a LOT less agressive than Lo-Fi or Sans amp. Is DUY the solution? Which plugin are you liking and what kind of settings? Anyother PIs that provide sweet harmonic distortion we should be checking out?
See my Public Profile for System Configuration Information
(Click on member name)
Old 11-10-2005, 07:18 PM
RIO RIO is offline
Default Re: Cranesong Phoenix presets
Robert,
Which Phoenix plugins (from the available 5) do you use most and to what effect?
Izhar
It varies depending on the mix, but I usually find myself going back to similar settings 90% of the time. I tend to use the 'Luster' plug-in, on the 'Saphire' setting with the process level set to maximum. Then I'll just alter the input trim to adjust how "hard it hits the tape". I don't hit it too hard but just enough to pull in some of the peaks so that the limiter doesn't have to work quite so hard. This setting adds a little bit of smoothness to the top end as well as brightening the it and will generally get another dB or two out of the mix. Doesn't work for everything but I use it an awful lot and wouldn't like to be without it.
Robert
Old 11-11-2005, 12:45 AM
Xavi - DUY's Avatar
Xavi - DUY Xavi - DUY is offline
DUY
Hi Josh!
Thanks so much for the reply! I forgot about the DUY analog stuff, those plugs do sound great. As much as I would like to get them all, it's just not in the budget right now.
Just to let you know that if any of our bundles is not in your budget, you can also purchase any of our TDM plug-ins individually... That is, for instance, only DUY Wide, or only DUY DaD Tape, DUY DaD Valve, etc...
They can be purchased through our online store at www.duystore.com as a download, or through any authorized Digidesign distributor, also as a download.
Best regards
Xavier - DUY
cservice@duy.com
www.duy.com
Old 11-11-2005, 04:53 AM
ashdot ashdot is offline
Thanks Robert.
I use Iridescent on practically anything, choosing any of the 3 eq curves according to the source material.
I use Dark Essence on overly bright and brittle vocals as an extra compressor that also smoothes the top end, Fairchild style.
Izhar
Old 11-11-2005, 05:14 AM
crizdee's Avatar
crizdee crizdee is offline
I only really use the DUY valve? it has presets for each instrument type! but oddly enough i'll often have a snare drum set to flute preset etc. just close my eyes and flick through the presets till one sounds right then do a bit of tweaking. i love it on individual instruments best and occasionally on busses.
R.E. Analogue chanel...
I have just used this on a mastering session with great success! the tracks were all a bit thin and cold! indie rock songs! and the analogue chanel was a great for adding what i call "rump and shake" the guitars suddenly sounded powerfull and warm and everything just glued together better.
i also use this a lot in individual instruments! especially drums when i want them to sound more tape like! just helps the other elements of the mix to be heard better! also use on electric guitars and acoustic when i want a softer sound for when its just guitar and vocal playing.
And phoenix gets a lot of use, for making things stand out in a mix!!
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 11-12-2005, 04:02 AM
derF derF is offline
I've just got a copy of Crane Song's Phoenix and I must say it's the best plugin I've bought in a long while. I'm still bashing away on my old Mix System and it really gives my mixes that extra "bit". I was considering Analog Channel as I've used it in the past, but I figured that my mastering guy uses all of Cranesong's gear so maybe there is something in it. I'm quite chuffed to report back YES!
Old 11-12-2005, 12:44 PM
minister's Avatar
minister minister is offline
i just got Phoenix too, and i must say, i am IMPRESSED! cool. it does add a lot to tracks and mixes that were missing in what i wanted to hear. can take a good, but clinical mix and fill out some 3D space.
i used AC a long time ago...maybe it is better now, but it was too subtle for me. it helped, but not enough some times. also, the qaulity, to my ears does not compare. i never went WOW! with AC. with Phoenix (maybe because it is new) i go WOW!
phoenix is so versatile...you can really dial in the amount you want. and it is DSP efficient!
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 11-12-2005, 02:37 PM
Imagine Imagine is offline
Having used both for quite some time, I find them both different. What works on one track may not work so well on another. Like anything else, it's a matter of preference, but I wouldn't say one is better than the other. They're both excellent plug ins.
Dean
Old 11-13-2005, 12:47 AM
Matt_G Matt_G is offline
Hi all, I was just wondering what DUC members think of the McDSP Analog Channel plugs and the Cranesong Phoenix plug-in. I'm in the market for one or the other, and I would like some opinions about how each perform. I'm particularly interested in how they "warm" tracks (add harmonics, etc.) Do they perform as advertised, or is it just a marketing thing? Are there other alternatives (non-hardware) that I am overlooking? If you could only have one (well, AC is 2 plugs, but...) which would you choose and why?
Any and all comments are appreciated.
JB
I own Analog Channel, a Cranesong HEDD 192, a Studer A809 quarter inch tape machine & I have also tried the demo of Phoenix. I tend to use Analog Channel & the Cranesong HEDD together in most sessions & quite often I will also go to real tape depending on the sound I want. To me the emulations don't capture the sound of real tape. For example the Cranesong HEDD & Cranesong Phoenix doesn't process the entire signal. It is a parallel process that adds a tape saturated compressed sound to the original signal. Analog Channel however does process the whole signal & can change the tone of the whole track & sounds different again & can add energy to the mids if set correctly. Real tape adds low level hiss, compresses the whole signal & sounds different to any of the emulations.
Given the current price of cheap 2 track tape machines I would be more inclined to buy a real tape machine. Try to get one that runs at 30 I.P.S. & have it aligned & biased for Quantegy GP9 tape. If you can get a Studer, Ampex or Otari for around the same price as one of the plug-ins you mentioned you will be amazed at how good it can sound strapped across your mix.
If it's convenience you prefer then one of the emulations can do a fairly nice job, although in my opinion not as good as the real thing.
Matt
Mastering Engineer
www.matthewgraymastering.com
Brisbane Australia
Old 03-10-2006, 12:49 AM
sgladm sgladm is offline
Hey, hope nobody minds i'm bringing this thread back to life...
Which MCDSP AC do you use, AC1 or AC2?
Also, do you usually engage the 'auto gain' when using it on the master bus?
Would love any feedback.
Thanks,
SG
cranesong phoenix / phoenix 2 question xcx VENUE Live Sound Systems 3 07-27-2013 08:29 AM
MCDSP analog channel V5 $100 rpagala Buy & Sell 2 11-01-2012 10:50 AM
McDSP Analog Channel rockrev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-01-2005 02:17 PM
Who's Using the McDSP Analog Channel doug_hti Pro Tools TDM Systems (Mac) 16 02-01-2003 02:18 PM
McDsp Analog Channel Lion Tips & Tricks 13 05-05-2001 10:34 PM
