Screen freeze, control 24 offline and RTAS overload messages fresh Leopard- PT8
Having had a few issues last week with the control 24 scribble strips flickering and getting RTAS overload messages, which I thought could be related to Leopard being installed over Tiger. I have done a clean install of Leopard and PT8 and only using compatible and latest versions of plugins. About once every few hours or so everything completely freezes for about 10 seconds, the control 24 faders go down, then the control 24 has lost ethernet connection error message appears, then the RTAS overload message then eventually it all starts to work again. If I’m on the desktop at the time the mouse even freezes there as well, so not just in PT does it freeze. The control 24 is connected directly to the mac (not connected through a network hub for checking) Everything is working 100% in 7.4 on Tiger and I worked all day Saturday like this no problems at all. Possibly related? When I minimize PT to go to the desktop etc. I noticed that PT will often stop sending the signal from Q-Capture to my outboard EQ after a while. This doesn’t happen in 7.4 and tiger! Once I maximize PT again and press play Q-capture starts to send a signal again?? Same 2 rtas plugs i always use for mastering Waves L3-16 and PSP Neon HR, 2 processors and the CPU meter jumping up and down like a yoyo! Lost on this one can't think of anything else to try!! back to 7.4 i guess Chris
Re: Screen freeze, control 24 offline and RTAS overload messages fresh Leopard- PT8
I too have had this problem recently, and removing a bunch of the plugins from folders has seemed to fix it for the time being. Any others?
www.leap-studios.com www.myspace.com/leapstudios www.myspace.com/leapstudiosmusic |
I have the same problems.
Everything is fine on 10.4/PT7.4 but lame on 10.5.5/PT8. Someone suggested disabling one of the processors (I'm on a G5). I'll try that. Digi, please help. Izhar Ashdot |
...spoke too soon. Once again I am having the same problems as before, and the session has very little plugin draw on the cpu (I've gotten away with WAY more RTAS in the past). I have just finished re-seating all the cards and ribbon cables, an will try running the same PT session as before to see if I still have a problem.
- I am running PT8 on 10.5.6 with an HD and accel card, along with a UAD-1 pci-e card and 8Gb of RAM.
We have a session from crizdee, but we're having trouble getting together a system that has all the plug-ins he's using. As soon as we do, we can take a look at this.
If you could all post your plug-in version list (use the tools in the General Troubleshooting thread), we might be able to find a common denominator. |
I decided to look into this a bit further and think i might have found something relevant. I noticed the scribble strips kept flickering very regular in PT8, so decided to video the control 25, and discovered that it keeps flashing the message "pro tools has a dialog on the screen" see utube video below! Now here's the good bit! I'm 99% certain it is happening when autosave is happening has all the signs; with autosave set to 1 minute... if i do nothing for several minutes then do a small edit it will happen, same as autosave! when doing small bits of editing less than a minute it will happen on the minute etc. Maybe this is causing the ethernet to disrupt? maybe this combined with the RTAS error messages is enough to make PT blow-out. it seems connected today when i was also using melodyne plugin and the screen would freeze for 2-3 seconds, sound would loop. CPU would overload then go to zero, press play and back to work for few minutes. Youtube EMPTY SESSION!!... http://www.youtube.com/watch?v=QK9_apu6XbY Chris
OK, I disabled the 2nd processor and PT8 now works like a charm.
Digi, please fix this. Izhar Ashdot G5 1.8DP, 10.5.5, PT8 HD3 |
Exactly what problems were you getting? screen freezes? control 24 offline? RTAS overload messages? Chris
However, if the problem is something else, we'll find out and implement a fix as needed. |
Just did a bit more testing! with 2 processors: overloading the RTAS CPU by inserting 5x Waves L3-16 and i get the RTAS over load message as expected, But also the control 24 goes offline quickly and all faders drop down then comes back again a few seconds later, and also noticed that the Elastic CPU meter also starts to show usage with 2 processors when RTAS is pushed With 1 processor: i can overload the RTAS cpu and i just get the RTAS overload message. This as well as what i found 4 posts up!! Chris
The Dreaded CPU Overload messages | Aerny | macOS | 2 | 11-19-2013 05:27 PM |
2.6.1 Rotary Encoder Issues, and MC Control Touch Screen Freeze | anotherchrisperry | Artist Series | 12 | 05-04-2012 01:45 AM |
HD Native. Offline bounce/Freeze? | lifer | Pro Tools HDX & HD Native Systems (Mac) | 4 | 10-08-2010 07:30 AM |
CPU Overload Messages with just M-Tron Pro | WernerF | Pro Tools TDM Systems (Mac) | 21 | 11-29-2009 08:19 PM |
Fresh tiger and pt install getting black screen | crizdee | Pro Tools TDM Systems (Mac) | 3 | 10-04-2005 11:30 AM |
