Old 03-04-2018, 09:09 AM
Geetar Geetar is offline
Default Recording software instruments using plugin's keyboard
Hey all, it's been forever since I've tried to record any midi without a controller, but I find myself this morning trying to get an arpeggio from Vacuum recorded into a track just by using the plugin's on-screen keyboard but it's not recording any midi into into the track. Do I need to enable something that i'm missing here?
I've got the software instrument track record enabled, vacuum is loaded and I can hear the audio coming through when I record, but no midi info is showing up in the region.
Probably something really simple - appreciate the help!
Old 03-04-2018, 12:44 PM
ChuckS ChuckS is offline
Default Re: Recording software instruments using plugin's keyboard
Not many VIs output MIDI. If the VI doesn't show up as an input for a MIDI or instrument track, then there's nothing to record. Also, even when dealing with hardware synths, the arpeggiator rarely outputs MIDI.
PT 2019.12 DP 10.11 VEP 7.x Komplete Audio6 HP Envy 8G i7 Quad Laptop Win10 (x64 2004)
PT 2019.12 DP 10.11 VEP 7.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.6
Old 03-04-2018, 01:57 PM
Indeed^^^ and to make music with plugin VI's, you really need some kind of midi controller. Assuming you have an available midi input, it can be any old(read CHEAP) synth with a midi output. I use an old Ensoniq Mirage that cost me all of $50
Old 03-04-2018, 02:55 PM
Wow, a Mirage! I used to have one. The guy I traded it to still has it and it's in VG condition. Nothing like an instrument with attitude - 8 bit. Ah, the 80s . . .
Old 03-04-2018, 03:16 PM
Ahhh, ok - the last time I had to do something similar, I was using Logic which has a "keyboard keyboard", so you can type in notes from the QWERTY keyboard... I'll wait till I get home and hook up my controller. Thanks, All!
Keyboard Controller not working with instruments dezst Pro Tools 12 10 02-22-2018 03:52 PM
Help - keyboard not playing instruments in PT8 stuartmlambert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 11-26-2012 03:18 AM
Changing Instruments with a Keyboard sarnoitaly Pro Tools M-Powered (Mac) 3 08-23-2011 06:26 PM
best keyboard for synth instruments? booinec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-09-2004 11:19 PM
keyboard instruments mismatched pajordan MIDI 8 08-12-2002 09:50 PM
