Old 12-13-2017, 05:49 AM
JulianMartin JulianMartin is offline
Default Instrument tracks not loading properly on PT12
Hey everyone !
I'm facing a problem regarding the instrument tracks on my Pro Tools 12.
Almost everytime I reopen a project, the instruments tracks' clips are grey, and of course not playing. (In the edit window of course)
There's a window at the bottom of the track header called "Patch Select", and I saw that the values are changing everytime I close and reopen a project.
A few weeks back I fixed it by changing those values to a "-" instead of the "0" showing, and choosing "none", but that doesn't work anymore.
I have to create a new instrument track, move my plugins and clips to the new track.
So... What happened ?? How can I fix that ??
I thought there was a conflict regarding MIDI with another software, but even with everything closed it's still the same thing...
Thanks a lot !
I'm working on a iMac Yosemite 10.10.5, and a Fireface 400.
Here's some pics :
Old 12-13-2017, 11:35 AM
K Roche's Avatar
K Roche K Roche is offline
Default Re: Instrument tracks not loading properly on PT12
Humm strange.
First to clarify are you talking about a PT cloud based "Project" or a disk based "Session"?
And you are talking about PT 12.0 not some later (. ) Dot release , the latest being 12.8 .2 R2 ?
So Patch Select values keep changing each time open the project/session ?
I don't work with Projects and don't know if it makes any difference BUT
I have had this happen a few times but so far, simply closing the session and reopening it make it go away
I just popped up a session with slate drums and my patch selection appears to have defaulted to "none" and (-) 's
One thing I have found with PT12 . *** when I run into a strange problem one of the first things I try is delete the click track, and see if that helps and then if I need it again I create a new click track
Other than than I don't know what to suggest.
System :
Avid HD Omni I/O Interface ...Mid 2010 Mac Pro/ processor- 3.33 6-core Intel Xeon "Westmere" w/ Memory- 24 GB, Radeon Pulse RX 580 8GB GDDR5 Dual HDMI Graphics Card..... OS- Mojave 10.14.6, and PTHDN 2019.12 on on primary boot drive (SSD PCIe 512 GB Samsung SM951) FCPX files storage on Samsung 970 EVO 1TB and PT sessions storage on 2nd Samsung 970 EVO 1 TB -- both in dual drive Crest I/O PCIE controller adaptor card
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Old 12-13-2017, 01:17 PM
Benoni's Avatar
Benoni Benoni is offline
You need to "connect" a valid MIDI source to the track. Instrument panel, and select a valid plugin and channel. In your case, EZdrummer.
Old 12-15-2017, 09:33 AM
Thanks you guys for your answers !
I got the latest update, 12.8.2 not sure if it's R2 or not... When I click 'Pro Tools >About' it says 12.8.2...
Yes, Benoni that works perfect, that part of the header was hidden. By me ! lol But why it's not saved with the project and doesn't open up correctly ?? Is it a bug from PT ??
Old 12-15-2017, 09:42 AM
KV626's Avatar
KV626 KV626 is offline
It is R2. They released it a couple days after "R1" came out. If you're not sure, re-download and re-install
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4
Arturia Keylab 88 Presonus Faderport 8 MOTU 896 iPad Air 2 w/ PT Control
NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc
Old 12-15-2017, 10:52 AM
Benoni's Avatar
I've had that happen too. I can't give you an answer, maybe a bug. Just remember to re-set the source if it happens again.
I guess I could report this.
Old 12-15-2017, 01:56 PM
Hanswurstlsepp Hanswurstlsepp is offline
This is since years - not always, but sometimes.
Cheers, STeff
MacPro5,1 , 32 Gig Ram, 2xATI Radeon HD 5770, OSX10.13.2  Pro Tools|HDX Ultimate 2018.4.0  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 01-29-2018, 01:33 PM
Geetar Geetar is offline
This is happening to me with EZDrummer 2 and PT 2018.1 now...
Old 01-29-2018, 01:38 PM
Raoul23 Raoul23 is offline
Very true I’ve seen this many of times in ProTools 10 HD
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Instrument track not playing properly in PT12 philjl77 Pro Tools 12 0 12-29-2016 10:50 AM
Instrument tracks on PT12.5 jglunt2112 Pro Tools 12 0 05-04-2016 09:27 AM
PT12 has less Instrument Tracks? adgjk Pro Tools 12 48 01-25-2015 04:41 PM
PT 11.1.3 Crashing upon loading session and won't properly Force Quit drummermixer Pro Tools 11 1 06-05-2014 05:20 AM
Plugin graphics (GUI) not loading/displaying properly??? DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 04-20-2010 06:06 PM
