Old 09-16-2011, 08:58 PM
nwheeler28 nwheeler28 is offline
Default PT9 on Lion: when i hit play on the transport, it pauses. any suggestions?
sometimes when I hit play on the transport, it pauses instead of playing (and the word 'pause' flashes in green in the Edit window even though I hit play). Similarly, when I arm it to record and then press play, the phrase 'record pause' flashes in red in the Edit window. Any advice on how to get it to play?
Old 09-17-2011, 05:14 AM
lemonkid lemonkid is offline
Default Re: PT9 on Lion: when i hit play on the transport, it pauses. any suggestions?
http://goo.gl/o12O5
You are not the only one!
Old 09-17-2011, 05:33 AM
paulrgmusic paulrgmusic is offline
It's not a solution but a workaround that's not too painful depending how often you need to do it (unless it's your livelihood).
Go to the playback engine, select a different buffer (128, 1024..it really doesn't matter, no need to press OK yet) then, reselect whatever you want it at and press OK.
Paul
2011 27" iMac
3.4 GHz i7
12GB RAM
500GB G-Drive Mini (FW audio drive)
Mac OS X 10.7.3 (Lion)
Pro Tools 10.0.1
Mbox 2 Pro (connected by FW)
Artist Transport: Application Lock Issues / Other suggestions Xill Artist Series 4 12-04-2014 11:08 AM
Can not stop transport. PT LE 8.0.4, Lion, Mbox mini, Macbook Pro skronger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-28-2012 07:53 AM
Playback Engine Press Play Then Instantly Pauses Sikin Pro Tools 9 4 05-20-2011 01:27 AM
PT8 automatically pauses when play is pressed Menprivin Pro Tools M-Powered (Win) 9 04-24-2010 11:03 AM
protools 8 pauses on play back rudyrhythmz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-08-2009 10:20 PM
