Old 11-29-2006, 03:10 PM
JLanclos JLanclos is offline
Default ProTools Crashing
So when i open a certain selection of sessions(all the same band), i get all the way to the edit window and PT locks up and closes with no warnings or anything. it only does it when i open a session from that band's folder. what do i do? it's an emergency!
-Jared
p.s. i'm using an Mbox 1 with ProTools 6.9
Old 11-29-2006, 03:49 PM
dubhausdisco1 dubhausdisco1 is offline
Default Re: ProTools Crashing
http://duc.digidesign.com/showflat.p...fpart=1#802377
You need to start here... There is not enough info in your post!
Old 11-29-2006, 04:08 PM
Antec Aria MicroATX case w/ 300W power supply
MSI K8M800-CE Socket 754 VIA K8M800 Micro ATX AMD
AMD Sempron 64 3000+ Palermo 800MHz FSB 128KB Socket 754
1 Maxtor 40GB system drive
1 Seagate Barracuda 80GB 7200 RPM 8M Cache SATA disk drive
1GB (2x512MB) DDR PC-3200 Ram
Sony DVD+RW/-RW Drive
Zalman CNPS7000B-AlCu CPU Fan
MS Windows XP Pro
Old 11-29-2006, 06:07 PM
The Weed's Avatar
The Weed The Weed is offline
Your old session may be corrupted. Try creating a new session with the same sample and bit rate as the session you are trying to open. Then import the session data from the old session to the new one.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Protools 8 keeps crashing... gabrieljay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-08-2010 04:49 PM
Protools Crashing Casper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-09-2008 09:18 PM
ProTools LE Crashing on Me Freakk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-31-2007 03:07 PM
Protools Crashing Benjamino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-09-2006 09:52 AM
Protools Crashing?... Icemaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-08-2005 09:48 PM
