Old 09-19-2006, 03:52 PM
east3rdst east3rdst is offline
Default Please help, time saving tips for bulk audio files
I'm working with thousands of 5-20 second audio files. They need to be adjusted. Some need to have 2 seconds added on to them, some need to have their volumes lowered. Also is there a way to import bulk regions on to a track. Dragging thousands of files from the region list to the track would take hours.
Thanks, this board has never let me down!!!
Donny
Old 09-19-2006, 03:56 PM
Drew Mazurek's Avatar
Default Re: Please help, time saving tips for bulk audio files
select the files in the bin, select the order that they will drop (vert or horizontal) from the audio menu and then drag them out to a track.
www.drewmazurek.com
Old 09-19-2006, 05:40 PM
Media Man Media Man is offline
Donny
I do this a lot. As much as I enjoy Pro Tools for all it can do, there might be a better solution that doesn't require all the "bounce to disk" action to create a new file.
If you have a PC sitting around, you might want to check out Sound Forge. Add a few seconds, save as, done.
mark
Old 09-19-2006, 05:50 PM
minister's Avatar
minister minister is offline
you can do this in PEAK using the batch processor and inserting 2 seconds of a blank file into the end of the file... it will also do volume adjusts.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Audio files are moved to wrong time after saving pt10 session for pt9 doubtful guest Pro Tools TDM Systems (Mac) 0 07-26-2012 11:05 PM
usaved PT session saving unsaved audio files to audio files folder mermermer Pro Tools HDX & HD Native Systems (Mac) 1 07-18-2012 11:50 AM
Saving structure patches in bulk suicune Pro Tools TDM Systems (Mac) 4 04-27-2009 11:52 AM
Please help, time saving tips for bulk audio files east3rdst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-19-2006 05:04 PM
Please help, time saving tips for bulk audio files east3rdst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-19-2006 03:50 PM
