-9136 Error when recording to ext. HD but not w/int. HD
Mbox (original)
Pro Tools LE v7.3.1cs6 Mac PowerPC G4 PowerBook 500 MHz 1 GB SDRAM OS X10.4.10 Digi CoreAudio Manager v7.3cs1 Glyph GT050Q External HD Mbox Playback Engine Settings: H/W Buffer Size: 1024 Samples RTAS Processors: 1 Processor CPU Usage Limit: 85% DAE Playback Buffer: Level 2 (Default) Tracks in use: 4 No Plug-Ins the problem: -9136 Hi. When i attempt to record to my external Glyph FireWire HD, i get: Error Message: CPU usage is holding off USB audio. Remove some Plug-Ins, delete some tracks, or increase the "H/W Buffer Size" in the Playback Engine dialog. (-9136) But when i record to my Mac HD with the same configuration, the error doesn’t occur and recording goes smoothly. (I’ve also been getting noise bursts and white noise while using Digi CoreAudio Mgr., so I installed Mbox Firmware v22 yesterday. Hope it’ll stop the shocking noise bursts!) What can I do to resolve the 9136 error and enable recording to my Glyph Ext. HD? Thank you. |
Re: -9136 Error when recording to ext. HD but not w/int. HD
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
i recently upgraded from v6 to 7.
-9136 Error | JazzyJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-21-2009 07:15 AM |
-9136 Error when recording to ext. HD but not w/int. HD | thelonious | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-08-2008 12:54 PM |
After 4 minutes I get error -9136 when recording 4 stereo tr | oswald808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-08-2007 03:05 PM |
error -9136 | zbaug5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-02-2005 12:47 PM |
9136 Error | beholder74 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-08-2003 12:36 PM |
