How to import MIDI Tempo and Meter data separately
I have a large session. I need to: 1) import MIDI *meter* information from an external MIDI file 2) run beat detective to determine tempo information from an externally generated audio click track that is supposed to be in time with the MIDI info imported above, but which has had some musical time compression/expansion added to it in post. The ultimate goal is to get the meters and bar lines to match exactly what is in the written score so that the tracking engineer can easily navigate through a 1000+ bar score and 75-minute session. I can import the meter from the MIDI file, which is great. I can also run beat detective and generate a perfect tempo and Pro Tools-generated click track, which is also great. The problem is that when I get the tempo identified, and write it to the timeline, it deletes all the MIDI meter information I imported. The same happens in reverse. If I generate the tempo first, and then import the MIDI file, the new tempo data all gets replaced with the tempo data from the MIDI file. Is there any way to import these separately, or is there a good workaround? Thanks - this should be so simple, and it would save me so much time. |
how to change meter/tempo and leave MIDI data the same? | J Morris | Getting Started | 5 | 04-03-2018 11:03 AM |
Bug: Import Session Data Clips Move when Tempo Changes | Dizzi45Z | Pro Tools 12 | 0 | 02-04-2016 09:45 AM |
HELP!! Can't Import Multiple Midi Files W/ Tempo Maps -Meter Maps | kfoody | Pro Tools M-Powered (Win) | 0 | 09-26-2011 08:08 AM |
Need to Change tempo but without changing existing midi data tempo? | Einsteinwannabe | Pro Tools M-Powered (Mac) | 2 | 09-18-2010 06:58 AM |
7.1cs9 import session data tempo problems | ilovemyssl | Pro Tools TDM Systems (Mac) | 1 | 09-05-2006 11:48 PM |
