Old 02-11-2011, 06:12 AM
SNAPPER SNAPPER is offline
Default PT9 without hardware attached?
I received my PT9 crossgrade last night and installed it on a new win7 PC. I registered the ilok and entered in my digi003 serial #. I was able to launch PT9 but then it complained that 'no hardware was found' (my digi003r is currently in a different location at the moment).
I thought PT9 was able to launch without hardware attached as long as you had the registered ilok inserted??? It was my understanding that I can install PT9 anywhere and launch it as long as I had my ilok with me???
Am I doing something wrong?
Thanks
Old 02-11-2011, 07:16 AM
mlemos mlemos is offline
Default Re: PT9 without hardware attached?
i'm pretty sure you have to install the ASIO4ALL driver which is a free download. a quick google search will take you right to it. (edit: here's the url http://www.asio4all.com/)
it allows PT9 to load an 'audio engine' when no hardware is attached.
good luck,
marco
Old 02-11-2011, 08:08 AM
brad383music's Avatar
brad383music brad383music is offline
Default
Thanks
Correct me if Im wrong, but I thought PT9 HAD to have hardware to operate, but unlike PT's of the past it didn't have to be DIGI hardware???
Hope this helps,
Brad
Win 7, PT 9, 11 rack, superior drummer 2.2, Gibson guitars, yamaha bass, Dimebag washburn
Eleven Rack + ERXP
Pro Tools 9
Windows 7
Gibson Guitars
Washburn Guitars
Michael Kelly Guitars
Yamaha Bass
Roland TD30K
EZ Drummer 2
Superior Drummer 2.2
Old 02-11-2011, 08:19 AM
no, i run PT9 on my laptop using ASIO4ALL and the built-in sound card.
Old 02-11-2011, 09:25 AM
Bill Denton Bill Denton is offline
Same here...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 02-11-2011, 09:36 AM
necjamc necjamc is offline
PT 9 will run with any asio interface. Including a built in sound card. But most built in sound cards do not have asio drivers, so ASIO4All is needed. I use it on 2 machines and it works fine. Obviously PT needs a sound card of some sort to operate. I think the confusion comes from the fact that most built in sound cards do not work on their own (with the standard drivers) so it's a bit misleading.
Old 02-11-2011, 09:41 AM
Default
I stand corrected. Thank you for setting the record (and me) straight. Cheers!
Eleven Rack + ERXP
Pro Tools 9
Windows 7
Gibson Guitars
Washburn Guitars
Yamaha Bass
Roland TD30K
EZ Drummer 2
Old 02-11-2011, 09:55 AM
true. so it surprises me that avid hasn't promoted asio4all more...just as a service to customers. i did allot of trial-and-error before figuring out that all i needed was asio4all.
i don't think it's misleading...just not obvious.
marco
Old 02-11-2011, 01:52 PM
Work with an audio interface—or without.
Get the flexibility of using Pro Tools 9 with your favorite Avid audio interface or third-party Core Audio- or ASIO-compatible interface—or use Pro Tools 9 completely standalone† for easy on-the-go creation.
Pro Tools on Windows requires the presence of an ASIO-compatible soundcard.
All written in different sections of the product page. So it's a little misleading based on the first sentence.
Do I need the Hardware attached to use ProTools SE? lifeisacabaret Pro Tools SE and Essential (Mac) 0 10-21-2012 02:30 PM
using protools without 002 attached mcclark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 07-08-2008 01:18 PM
Running LE without 002r hardware attached ? wangell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 31 12-28-2005 10:18 AM
Using Pro Tools with no hardware attached... chris002r 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 33 06-03-2005 12:33 PM
How to Start LE to mix without attached to 002? RobertJackson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-06-2004 06:21 PM
