Old 12-05-2010, 02:23 PM
sundontlie sundontlie is offline
Default Multiple Sound Source Talk Show Style Mix
I have a show that is set up like "The View". Multiple hosts plus guests placed semi circle around a big table. Everyone is talking over everyone else making it sounds quite messy.
Normally, I would isolate who was talking and manually pulled down the other tracks to clean up the mix. Though with 10 iso tracks plus guest mics it's a lot to manage quickly. The signal to noise is such that talking and not talking are close to the same volume so using the waveform isn't always working as I'll miss a quick comment or side note. Expanders are running to help though with the high signal to noise it's not much help.
It is taking awhile to ingest the conversation, decide who is leading, which comments need to be heard and then mixing it. Does anyone have any tips or thoughts as to how to quickly get through cleaning up all the open mics inherent in a show like this? Any thing would help. Thanks.
Windows XP
Pentium(R) 4 CPU
3.2GHz
3GB of Ram
78Digi002 w/ DV Toolkit
Old 12-05-2010, 06:19 PM
soundthinker soundthinker is offline
Default Re: Multiple Sound Source Talk Show Style Mix
Check out Dan Dugan's line of auto-mixers.
http://www.dandugan.com/
-jim
James Slanger
HD3 Accel PT9HD
Old 12-05-2010, 07:52 PM
Postman Postman is offline
Is this live or a remix? If it's live, then an auto mixer may be very helpful as long as the gain change is only something like 5db per mic. You don't want to miss a new person's first words. Auto mixers have an unfortunate consequence in your situation where if you have the thresholds set low enough to turn on for normal speech, they all turn on when one person in the room gets very loud, which kind of makes things worse. Ya cannu change the laws of physics. If this is a remix situation, I don't understand the question.
Old 12-05-2010, 11:59 PM
This is true, but at least for every mic that crosses the threshold they lower all the mics enough to keep the noise floor relatively constant. For example:
If one mic is above the threshold, it's not attenuated.
If two mics are above the threshold, they both are attenuated 2dB
If three mics are above the threshold, all three are attenuated 3.5dB
I use these mostly for live mixing of shows like you are dealing with but have used them in post-production on occasion for pre-taped shows. Set them up as a post-fade insert and use the Pro Tools automation to help them along a bit. A control surface would greatly speed up this process.
-jim
James Slanger
HD3 Accel PT9HD
Old 12-06-2010, 02:22 AM
idris idris is offline
I may be missing something here, but could you use Duckers? (ie a Limiter with the sidechain fed by the other channels.)
This may be the same as a n Automixer.
PT12.4.0 / HDN / HD Omni / MC Control / Intensity Pro / El Capitan / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM
Over 15yrs experience in TV. Currently mainly indie features.
Old 12-06-2010, 07:28 AM
I stand corrected then! Years ago I used an automixer on a gig. It didn't reduce overall gain with more active mics, the inputs were either at full gain above threshold or reduced gain. It turned me off of auto mixers. What you describe is much more practical. "Gain sharing" I think Dan Dugan called it. My experience (and earlier comments) are based on gating technology.
Old 12-06-2010, 10:08 AM
Yeah, I can see why.
I've only used the Dugan units and they've been great. Sure licensed the algorithm from Dan a while ago and had a similar device.
-Jim
James Slanger
HD3 Accel PT9HD
Old 12-06-2010, 02:19 PM
jeremiahmoore jeremiahmoore is offline
Ditto on the Dugan recommendation. It's a pretty smart algorithm, also balancing the noise floor so it remains relatively constant and doesn't pump.
I believe there is work underway toward a plug-in version as well.
-jeremiah
Old 12-07-2010, 12:25 AM
This quick note from Dan Dugan (who is apparently having difficulty logging in to the DUC at this moment...)
- Dugans don't have thresholds
- Shure has never done anything like gain sharing.
Old 12-07-2010, 05:34 AM
I think I had used a Shure unit.
HTML code is On
Routing to multiple outputs from one source broken? bleen macOS 4 11-19-2013 11:54 AM
source connect for long radio show? cubivore Post - Surround - Video 14 02-02-2011 09:12 AM
Festival style show files mackerr VENUE Live Sound Systems 2 08-13-2010 12:44 AM
Multiple Devices Connected To 003 - Clock Source Advice Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-31-2008 04:13 AM
Saving confusion with multiple sound source Mike Jones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-26-2005 01:42 PM
