Old 10-19-2010, 06:02 PM
ricschnupp1081 ricschnupp1081 is offline
Default Automated Scripting For 15,000 Bounces Of One Song
We need to output 15,000 different mixes of a single 1-minute song, each version with a slightly different lyric.
Recording the performances isn't the difficult part. We are only required to replace one word for each version. The awful part will be in the bouncing process.
PROBLEM ::
How can the task of outputting mixes (bouncing) be scripted so that it happens automatically, without requiring any keystrokes or mouse work for each mix? A solution will require a script that:
1) automates the selection of the next vocal take (or playlist),
2) selects the area to be bounced,
3) gives the bounce a unique title,
4) bounces
5) starts the script over again.
Is Applescript a solution?
Thanks for your help,
Ric
Old 10-19-2010, 06:52 PM
BGMusic BGMusic is offline
Default Re: Automated Scripting For 15,000 Bounces Of One Song
This is some sort of a joke, no?
Old 10-19-2010, 07:12 PM
soundthinker soundthinker is offline
ProTools isn't directly scriptable. You may be able to do this with Quickeys.
I don't think Logic is scriptable. Reaper has ReaScript, but I'm not familiar with it's capabilities.
Old 10-19-2010, 07:52 PM
ronwasserman's Avatar
ronwasserman ronwasserman is offline
You don't need a script, you need an intern.
Ron Wasserman
http://www.ronw.com
http://www.imdb.me/ronwasserman
http://www.fishertheband.com
Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version.
Old 10-19-2010, 09:15 PM
FajitaTone FajitaTone is offline
can you even have 15,000 playlists?
Ray Trujillo
Freelance Audio Engineer
Old 10-19-2010, 09:48 PM
ekuehnl's Avatar
ekuehnl ekuehnl is offline
ACI/ALP Moderator
Bounce the song once without the lyric in question.
Record the 15000 individual lyrics and export them to a folder.
Then use the batch function in a different app like Peak/SoundForge/etc for a faster than real-time mix of the bounced song with the each of the 15000 instances of the lyric. If you set it up correctly, you can just point the app at the folder with the 15000 files and click the button. Then come back a day later and it will be done.
Easy. And well worth the cost of one of those other apps in time saved. You might even be able to do it with a demo copy.
-EK
Old 10-20-2010, 05:45 AM
jeremyroberts jeremyroberts is offline
I like EK's idea of using a different app, and only bounce the lyric change then merge.
15,000 60-second files = 250 hours without any pre-or post-processing time.
Ric needs to use an app that will mix/bounce faster than real time, else this job will take months. At realtime, 15,000 60-second files will take a minimum of 11 days assuming everything is fully scripted. And that is without any file operation overhead. SO figure 30 seconds per file for overhead. SO add 6 days.
Ric MUST use a faster than real time app to do this.
And data management/file naming conventions must be well thought out.
Is this a "your kid's name embedded in the toy" project? Why not just use a multi--channel playback engine, so instead of custom recording a zillion songs -- add a channel of playback???
--Jeremy
Audio Bounces are longer than my song? Mr_Seven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 20 11-14-2021 01:36 PM
Seeking an EDL scripting app tonepad Post - Surround - Video 19 12-08-2009 09:56 PM
Bounces to include song title and artist info Vivo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-17-2008 05:08 PM
scripting Pro Tools; automation Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-01-2004 12:38 PM
scripting in PT DaveP Pro Tools TDM Systems (Mac) 3 07-04-2001 05:10 AM
