Old 04-14-2021, 12:24 AM
fl0645 fl0645 is offline
Default Contour Shuttle Pro 2
Hello, I want to use a shuttle pro 2 contour but I have the impression that there are no keys in PT (normal not integral) to configure the dial, for a progressive front/rear listening, what is it possible to do? Thank you in advance!!
Old 04-14-2021, 04:03 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Contour Shuttle Pro 2
On Mac anything you can program on Keybord>Shortcuts can be controlled from the shuttle. I have one and have it programmed to do all sorts of things. the wheel can be programmed in steps, so the further you turn the wheel the more steps it can do, i use it to make track view bigger and to navigate left right in the mix wondow.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-14-2021, 09:32 AM
Thanks, actually I have two problems: I have a French azerty keyboard and the shortcuts do not match, as indicated in the pdf of avid pt, I would like to be able to move forward and backward on the time-line but the reaction of the shuttle pro is weird, not smooth and the cursor does not move, it was to avoid buying avid dock, the numeric keypad no longer works properly (num 1 and num 2) to move back and forward while being in audio playback, on the other hand, the jumps work, I haven’t tested all the shortcuts yet.
Contour Shuttle Pro v2 Craig F General Discussion 0 01-23-2015 02:07 AM
Anyone using a Contour Shuttle Pro with LE? citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 05-20-2011 12:59 AM
Contour Shuttle Pro imloggedin General Discussion 0 02-17-2010 01:27 PM
PT 6.0 and Contour Shuttle Pro Larbabe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-07-2003 11:35 AM
OT: Contour Shuttle Pro yes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-26-2002 01:47 PM
