Pro tools LE won\'t run on laptop and XP
Hello,
My pro tools 6.7LE/m box won't run on my 2.8ghz laptop!? it used to run fine with 6.4, but i have installed 6.7 from CD and i am getting error messages... first error message says "audio processing is in conflict with other CPU tasks, try reducing the HW buffer size -9129" i reduce the buffer size! and then get this message.... "the operating system held off interupts far too long, try increasing the buffer size" I have tried all buffer sizes and have tried DAE buffer size!! This even happens with an empty song with no audio playing!!!!!!! I have uninstalled from CD and installed again with no difference!! i desperately need to get this system to work!!! any help would be appreciated. Regards Chris
Re: Pro tools LE won\'t run on laptop and XP
So tell us are you running SP2?
jazzmandan
~2004 - Dell 4600 P4 3.0GHz, 2.0 GB Ram, XP Home SP3, 80GB HD for System, 120GB HD for Audio BIAB 2009, Pro Tools 8.0, MBox 09/12/2009 - Dell XPS 435T/9000 i7, 6G Ram, Vista 64 Bit 750 G SATA for System, 1TB SATA for Audio, Protools 8.0.1, MBox 10/31/2009 - Win 7 64Bit MBox /PT not supported under Win7 - I didn't leave PT, PT left me! 11/30/2009 - MBox, REAPER http://www.jazzmandan.com |
Chris tell us your specs including version of XP you are using.
Haven't seen this issue yet. In the meantime you may want to have a dual boot system with PTLE 6.4 on one. Allen |
Hello,
I am not running SP2 only SP1 has been installed! i am running XP home edition. This system was running fine on 6.4 but i upgraded to 6.7 a few weeks ago and this is the first time i have actually tried to run a song since the install!! I have uninstalled from the 6.7 CD and done a fresh install, but no difference, it still won't run longer than 10-15 seconds before error messages. I have tried turning off Norton anti virus and firewall. Sony VAIO 2.8ghz 512 ram 60gig HD PT 6.7 LE cs8 mbox Regards Chris
Laptop PC for Pro Tools 10 | Mikolaj1022 | Windows | 9 | 06-15-2012 03:13 AM |
Using My 002 With Pro Tools HD 10 Laptop??? | Jay Terrien | Windows | 11 | 06-10-2012 08:20 PM |
Will my new laptop run Pro Tools 9??? | blankguitar | Windows | 1 | 03-13-2012 03:57 PM |
Getting Pro Tools to run on HP i7 laptop | Rythameen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 01-19-2010 12:29 PM |
Pro Tools LE 5.1.1 on laptop? | Brady | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-08-2002 05:53 AM |
