#61
Re: Horrible VI performance when recording in 2019.10!
256/48000=5.33ms
You need to have a lousy AD/DA to go over the "about 10ms" threshold that is good enough for monitoring.
#62
In ears or wedges? If the latter, of course they wont complain. It bugs the crap out of me when people say 256 is acceptable. Find me one VO person who finds that acceptable. Decades of recording VO and complaints unless it was LLM or analog path. Comb filtering is VERY real. |
#63
Yeah sorry but I agree with Sardi here. We record big popstar artists from the US and Europe aswell and anything over 64 is not gonna work with these seasoned artists. They would hear a ”delay” as they say or say they hear themselves twice when trying to explain as ”latency” is not the word these youngones use.
So 256 is unreal but if you (Jfreak) work with church and hobby people then maybe but in the studio with real artists anything over 64 is a no go. Period!
#64
My theory goes like this; when singing you hear both the signal in headphones and your voice actually resonating inside your head! Any latency at all in hp's - and you get comb-filtering between the two. But this is of course especailly singing with headphones. The tolerable amount of latency depends on the situation. |
#65
With respect to all posts here, all of this is psychology not physiology. You can monitor yourself with 256 buffer if you are alright, but if you have a bad day you want to make it look the problem is something else not you. I said I have 99% success rate of fixing the delay problem by pressing a mute button for few seconds. It comes down to psychology; you tell the artist the problem is fixed and the brain thinks something has changed. I have done this since 2002 and very few times I have had to say "okay I reduce it a little more" in which case 128 has been the happy buffer.
You should do a blind test. Have your buddy set up an unknown buffer and monitor yourself. When you cannot sing/play you know what is too much. My experience is 256 fine 512 disaster. It is a mind game.
#66
Maybe someone remembers better but I dont think there even was an option to go lower than 128 buffer when DigiDesign introduced their LE hardware line? Back then we did not have this problem
#67
We ran 2" 24 track studer back then as LE was never an option for us. We used HD from the day it came out but kept using 2" until HD8.1 when PT was starting to be great
#68
And should you ask me why I do this.. well.. as a mixing engineer I want to have all the horsepower possible at my disposal. So I start with 256 buffer I know is physiologically possible, which leaves me as much CPU as possible. If the artist is picky, I need to give up some and the artist may not get all plugins I would likely use. Just practical thinking.
#69
If you ask me, PTHD 8.1.1 is best there ever was, stability-wise
#70
UAD solved that part of it for me at least, but even with that, I have to avoid certain effects that add too much latency. If you don't believe me, there is nothing more I can do to convince you, and that's ok. Peace.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
PT 2019 Mojave performance improvements | bartosz idzi | Pro Tools 2019 | 8 | 05-17-2019 01:10 PM |
Horrible Latency when recording in Pro Tools 11 | FJ92 | Pro Tools 11 | 4 | 04-22-2016 10:09 AM |
Recording quality suddenly horrible? PT8 - files in here. | masta1 | Pro Tools M-Powered (Win) | 7 | 04-03-2009 10:11 AM |
Horrible noise on bass amp when recording! | idledude | Pro Tools M-Powered (Mac) | 6 | 01-07-2009 12:57 PM |
Horrible, Horrible, Skreeching Noise On Drum Track in Sampletank | William.E.Lemuel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-09-2002 06:54 AM |
