transfer files from Pro Tools LE to M-powered
Is it possible to make some music in M-powered and then continue mixing it in Pro tools LE? A friend of mine have the M-powered version while I have LE and we want to be able to send the files to eachother to mix it in our own programs.
Re: transfer files from Pro Tools LE to M-powered
There is no difference whatsoever.
The exeption is if you have the DV Toolkit or Complete Production Toolkit (they cost thousands of dollars extra.) And even so it would only be a problem if you used features spesific to those toolkits (like surround mixing, more than 64 audio tracks..) So you`ll be fine.
Stian Sylta Producer/Songwriter/Musician Sons Of Vanity on iTunes/Spotify MacBook Pro i7/Apogee One/Duet/ElevenR/Pro Tools 12 Preamps from UA, Mackie and Avid. Listening through Dynaudio, Genelec and ADAM |
I used to have (at my old job) an M-Powered system, using a M-Audio Delta 66 card. At home I have a 002R LE system. I used to transfer sessions back and forth all the time... no problems. The only difference was that at home, everything on my system ran through the ADAT optical cables in and out of my mixer, where as at work it was all analog, so all I had to do was change my I/O setup in the session itself... no biggie.
So yes, you should have NO problems what so ever. Cheers J |
Pop in Audio Files - Pro Tools M-Powered | MichaelKhan | Pro Tools M-Powered (Win) | 0 | 09-15-2010 11:17 AM |
Missing! Structure Instrument Files - Pro Tools M-Powered Essential | chadgeek2 | Pro Tools SE and Essential (Mac) | 3 | 09-06-2010 10:23 AM |
Reading Pro Tools 6 Files on Pro Tools 7 or 8 M-Powered Systems | longmansleep | Pro Tools M-Powered (Mac) | 0 | 05-08-2010 03:09 PM |
PC M-POWERED SESSION TRANSFER FILES TO MAC TDM QUESTION | dave2005 | Pro Tools M-Powered (Mac) | 0 | 03-22-2007 10:15 AM |
Transfer Audio FIles From Pro-Tools LE 5.1 sessions to 7.3 | MITD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-21-2007 03:41 PM |
