Old 09-09-2007, 08:33 AM
sixgroovenine sixgroovenine is offline
Default Protools Playback starts and then stops immediately
I was working on a session that was working fine and all of a sudden it stopped playing back. The playback button lights and then the stop button lights up immediately. Someone suggested it was waiting for sync but the sync button is not lit. I've looked through all the menu's and cannot figure out what it is. I imagine I must have hit a quick key or something. I even tried bringing the tracks into another session but nothing works. It's not a CPU error or anything because even if I make all but one track inactive it still happens. Please help I'm very frustrated.
G4 Ibook
Digi 002
Firewire Drive
Assistant Engineer
Circle House Studios
Old 09-09-2007, 11:02 AM
Slim Shady Slim Shady is offline
Default Re: Protools Playback starts and then stops immediately
You don't list your system specs so it's hard to help.
However, there was an issue like this with earlier version of PT7.x. Have you done the steps in the "General Troubleshooting" thread already? That should take care of it.
Old 09-09-2007, 11:10 AM
Chris7514 Chris7514 is offline
Hi !
The same thing happens with my setup ( PT 7.3.1 with DIGI 002 R). I push "play" space bar, and it stops immediately after it starts. I had NEVER have this problem with earlier versions of PT, that's why yersterday I switched back to PT 7.1.1. The problem went away ! It's PT 7.3 software that's causing the problem !
Chris7514
Old 09-09-2007, 12:24 PM
I haven't had that issue since v7.1, PTLE 7.3.1 is working like a champ for me, no problems. With 7.1, a quick visit to the Playback Engine dialog and toggling any setting in there brought things back to life again.
Dual G5 2.5 / 4.5gb RAM / 2x500gb SATA. / Digi002r
Old 09-09-2007, 02:07 PM
The Dougfather The Dougfather is offline
This is a buffer error with the added confusion that Pro Tools doesn't tell you. Adjusting the H/W buffer will resolve the problem. I haven't seen this since 7.1 and i've never had it on an intel mac only on the old PPC.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Pro Tools playback starts and immediately stops doughthedj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-10-2008 08:13 AM
Sliders Reset When Playback Starts or Stops Benji Lea 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-02-2007 01:02 AM
protools 7.3 playback stop immediately shinaz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-15-2007 10:01 AM
Video Stops in Loop Playback then Starts? joepopp Post - Surround - Video 0 04-25-2007 07:40 AM
Playback Issue! Play starts then stops immediately RSSstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 51 04-25-2006 11:02 AM
