Re: Setting up Single Clock Source
And also how do I connect one converter to the other so they all sync? |
You connect the digital output of one device to a digital input of another device and set the device receiving the signal to sync to the source's clock.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
^^^^ Those bottom two quotes aren't me. They are jd1234.
(quote bracketing got off)
Pro Tools Ult 2024.3, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire HD10 + Max11, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.5 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Fixed it - sorry!
You can't, which is why I made the suggestions earlier. Sell the Rosetta and connect the 1073 to a line input. Or, sell the Mbox and get a used 003 which CAN handle 2 digital inputs(on RCA SPDIF and optical SPDIF).
#16
Thanks all for the feedback. So it sounds like these chains have to be used separately cause MBox is only capable of receiving one digital source at a time? A 003 is capable of of handling 2 digital sources at the same time?
To be honest it is not so much a problem for my purposes right now. For guitars, mainly acoustic, I use the API which has 2 channels. And for Vox using the Neve and Rosetta combo. The issue I am more concerned with is that I am forced to use the MBox’s internal clocking system instead of the SPIDIF clocking system right? If I am bouncing back between 2 different converters (API and Rosetta) on any one song it is probs better to keep the clock source with Pro-Tools right?. Is that the right move? When recording with different converters (each using SPIDIF) is it always better to set the clocksource as “internal” with MBox? Or am I missing out on the advantages of using a converter (SPIDIF) as a clocksource? How does this effect the finished product and overall sound? |
Problem detected with audio clock. Check your clock source and sample rate. | sleeptalken | Windows | 7 | 08-10-2021 01:17 PM |
Setting clock source for 11R | Legion6789 | Eleven Rack | 6 | 12-04-2011 06:17 PM |
PT 8.0.4 is re-setting my clock source.... | JayStyles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 10-23-2010 06:54 AM |
"Problem detected with audio clock. Check that your clock source and sample......... | ASD15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 03-26-2010 03:40 PM |
Setting up Digi 002 to External Clock source????? | SmoTools | Post - Surround - Video | 5 | 08-17-2006 11:30 AM |
