Old 02-08-2010, 08:26 PM
babakdm babakdm is offline
Unhappy PT suddenly made my tracks out of sync, help!
HELP!!!! After closing and saving a session I had worked on for 3 days, I opened it back up to review something and all of a sudden, the tracks were not in sync (e.g., keys are not in sync with Strike and vocals). Also, some empty spaces between recordings, on the same track, appeared gone and the separate recordings (on the same track) were now linked/attached. And, other similar weird stuff... I closed and reopened and noticed that everything appears to move right after the session loads (in other words, it seems to load normally and then the aforementioned happens). I tried opening a different saved session and that changed too! I'm wondering if somehow I accidentally pressed some key on my computer keyboard or on my Axiom Pro that selected an option that makes this happen to my tracks. How can I fix it? Hopefully, it's just an option I need to change, maybe under Time Operations (hey, I'm a newbie!). HELP, PLEASE!
THANKS!
Bobby
I'm using:
Pro Tools M-Powered 7.4 (with updates, I think cs3) with a FireWire 1814
SiSoftware Sandra
Processor
Model : Intel(R) Pentium(R) 4 CPU 3.00GHz
Speed : 2.99GHz
Cores per Processor : 1 Unit(s)
Threads per Core : 2 Unit(s)
Internal Data Cache : 2x 8kB, Synchronous, Write-Thru, 4-way, 64 byte line size, 2 lines per sector
L2 On-board Cache : 2x 512kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 lines per sector
System
System : Dell Computer Corporation Dimension 4600i
Mainboard : Dell Computer Corp. 0F4491
Bus(es) : X-Bus AGP PCI IMB USB i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
System BIOS : Dell Computer Corporation A09
Total Memory : 2GB DIMM DDR
Chipset
Model : Dell 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface
Front Side Bus Speed : 4x 200MHz (800MHz)
Memory Bus Speed : 2x 167MHz (334MHz)
Video System
Adapter : NVIDIA GeForce FX 5200 (128MB DDR, 249MHz/2x405MHz, AGP 3.00)
Storage Devices
IC35L090AVV207-0 80GB (ATA100, 3.5", 7200rpm, 2MB Cache) : 75GB (C:)
M-Sys Dell Memory Key 123MB (USB) : 117MB (H:)
ST3250310AS 250GB (FireWire/1394, 3.5", NCQ) : 233GB (G:)
HL-DT-ST CD-ROM GCR-8483B (ATA33, CD-R, 128kB Cache) : N/A (E:)
SAMSUNG CDRW/DVD SM-352F (ATA33, DVD+-R, CD-RW, 2MB Cache) : N/A (F:)
Logical Storage Devices
Hard Disk (C:) : 74GB (NTFS) @ IC35L090AVV207-0 80GB (ATA100, 3.5", 7200rpm, 2MB Cache)
CD-ROM/DVD (E:) : N/A @ HL-DT-ST CD-ROM GCR-8483B (ATA33, CD-R, 128kB Cache)
CD-ROM/DVD (F:) : N/A @ SAMSUNG CDRW/DVD SM-352F (ATA33, DVD+-R, CD-RW, 2MB Cache)
Removable Drive (H:) : 117MB (FAT) @ M-Sys Dell Memory Key 123MB (USB)
Volume 1 (G:) : 171GB (NTFS) @ ST3250310AS 250GB (FireWire/1394, 3.5", NCQ)
Peripherals
LPC Hub Controller 1 : Intel 82801EB/ER (ICH5/ICH5R) LPCInterfaceBridge
LPC Legacy Controller 1 : SMSC LPC v1
Audio Device : Dell SoundMAX Integrated Digital Audio
Serial Port(s) : 1
Parallel Port(s) : 1
Disk Controller : Dell 82801EB/ER (ICH5/ICH5R) EIDE Controller
Disk Controller : Dell 82801EB (ICH5) SATA Controller
USB Controller 1 : Dell 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1
USB Controller 2 : Dell 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2
USB Controller 3 : Dell 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #3
USB Controller 4 : Dell 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4
USB Controller 5 : Dell 82801EB/ER (ICH5/ICH5R) USB 2.0 EHCI Controller
System SMBus Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : HP Photosmart C6100 series fax (200x200, Colour)
Printer : HP Photosmart C6100 series (1200x1200, Colour)
Network Services
Network Adapter : Intel(R) PRO/100 VE Network Connection - PacketSchedulerMiniport (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 2)
Platform Compliance : x86
Performance Tips
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Instrument tracks crash and have to be made inactive to work again Moviesound macOS 0 05-04-2012 07:36 AM
PT8 - instrument tracks won't play when made active conjure.one Pro Tools TDM Systems (Mac) 4 06-04-2009 01:30 PM
error 7100 & plugins and tracks made inactive Sharabelle Pro Tools TDM Systems (Mac) 0 01-07-2007 04:04 PM
Ableton 5 Suddenly Out Of Sync Third Eye Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-10-2005 03:40 PM
sync midi drum tracks to wav tracks Adrian D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-14-2003 12:24 AM
