SC48 Monitors
Hello All,
Myself and the fellow techs have been trying to solve a problem for days! We have our reverb and delays setup through the FX and routed to Aux 1 and 2 locations on the board. However, we cannot figure out how to put the effects in the IEMs or stage wedges. Any ideas?? Also, the Sc48 has not been updated in the last four years. Thanks, TtT |
Re: SC48 Monitors
Where is the fx signal returning on the board? Is it routed to the fx inputs? You only need to open up the auxes from the return channel to the mix you wish to send the wet signal to.
If the sc48 is on v3 software, you're good. |
Re: SC48 Monitors
Yes through the FXs.. Thanks for the reply, I will check that when I am in at that venue again!!
Re: SC48 Monitors
The board is on version 2.6 still looking for a solution.
Re: SC48 Monitors
Any reason you can't upgrade? Well worth it in my opinion.
Re: SC48 Monitors
I do not own the board, the church I mix at does and has not upgraded it. Not my call to make. Is this an easier feature to set up on the newer versions?
Re: SC48 Monitors
I'm not sure I understand the problem.
Where do the FX return now? One of the 8 stereo FX channels? Select the return channel and use the Aux Sends to put the reverb in the IEM mixes. It's treated like any other input that you want to send to IEM. |
Dual monitors: Can I have my mix and edit windows on different monitors? | songwritersoul | Pro Tools HDX & HD Native Systems (Win) | 5 | 05-23-2014 11:16 AM |
VCA on MONITORS SC48???? | gregoverman | VENUE Live Sound Systems | 3 | 08-10-2012 09:56 PM |
VNC with SC48 and monitors. | TheMAXX7 | VENUE Live Sound Systems | 1 | 02-25-2012 03:02 AM |
Make Studio Monitors as Desktop Monitors through Mbox2 ???? | dcwang3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 08-17-2007 08:02 AM |
Monitors: $1500-$1800 budget . Which Active Monitors? Suggestions and Help Please. | betsy | Pro Tools TDM Systems (Mac) | 52 | 12-15-2003 10:11 PM |
