#21
Re: Mini Grand Mixing Question
yea but it costs a fortune for me ... can't afford to spend anymore .. I was looking for a quick fix solution .. I guess the thing I was looking for was the timbre more clear .... any quick EQ fix ?
System Details: iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz Macbook M2 Pro macOS 14.4.1 Pro Tools 2024.3.1 Logic Pro X Reason 12 UA Apollo 8p Apogee Thunderbridge/Apogee Symphony I/O 2x6 Eleven Rack/Focusrite ISA Two/Onyx 1640i UAD Satellite Quad MOOG Mother 32 Nektar Panorama P1 Axiom AIR 49/Axiom 49/Yamaha P35 Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e Genelec 8040b/Yamaha HS80s/M-Audio BX5a Beats Solo/Shure SRH1840/Slate VMS https://open.spotify.com/artist/7KfV..._branch=1&nd=1 |
#22
There is no quick EQ fix, because it depends on the song you are mixing. As musicman said, play the whole song (not the piano only) and EQ the piano untill you like it!
Mini Grand tip: get rid of the low "kick-like" sound of the Mini Grand.
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
#23
Guys please ... I am just playing piano solo .... no other instruments... no drums...nothing ... how can i brighten its sound no more no less ..
#24
Well it's always depending on what you are looking for and really there's no quick way for this. But here's a little guide line. If you are looking to boost a bit of the attack of the piano, maybe hear a bit more of the hammer noise (not that there's any in the Grand Piano) then you will want to boost the mids at about 5khz and a little bit upward, don't over do it though. And the best way to do that is to reduce the lows and highs around the frequency you want. Substractive EQ is always the best because it does not introduce artifacts (yes there is some even in digital, frequencies don't appear out of thin air). YOu can boost your mids until you find the sweetspot then bring them back down to 0 and bring the lows and the highs down by an equal measure of what you had boosted your mids. So if you had a +4 db at 5khz, you would bring everything that is above and below that point down by -4 db while the 5khz remains at 0 db.
If on the other hand you are looking to bring in more air into the piano, then you will want to accentuate the highs above 12khz. Again use good eqing techniques with using subtractive eq. It is all a listening moment though, so you will have to go and try it out audibly until you find what you wish. |
#25
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
#26
Thank you guys ! :)
#27
Yes. Jordan Rudess is happy about that piano, I don't know who isn't.
#28
Yea ... it's also displayed on Pro Tools 11 trailer with Waves Element etc ...
Mixing issues for Grand Piano | dan2004 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-29-2011 12:35 PM |
Mini Grand | Sune Lynge Rasmussen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 12-22-2009 10:35 AM |
Mini Grand | shultzee13 | Tips & Tricks | 1 | 05-21-2009 10:12 AM |
Mixing Grand Piano | Riccardo Corbari | Tips & Tricks | 4 | 01-28-2005 11:59 PM |
Mixing Grand Piano | nehemiahmh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 10-28-2004 10:33 PM |
