Re: Mini Grand Mixing Question
+1
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Like other things you've asked about there are no standard eq's used. Compressors aren't usually used with piano recordings and won't really help with the sound you're looking for. That being said if I use any eq on a piano it's the Passive eq from NI - it's one of those Softube did that is a Manley emulation. Specifically it's a Manley Massive Passive eq emulation. Careful tweaking should get you where you want to go but the soul of this is you have to find what works for you and the library you are using. And ALWAYS keep in mind to eq in the context of the mix the piano will end up in as a solo'd instrument might sound great but in the mix sounds like crud. Or vice versa - a solo'd instrument is the pits but could be just what the mix needs when played with the rest of the tracks. |
ok so let me get things straight .... you said that the Alicia Keys piano might be the one I am looking for since it is the one mostly used in a lot of rock songs ??
then, as you said, you wouldn't rather use an EQ for any piano playing solo but rather when it's in a whole mix .... fine ... but then this mini grand is a steinway which is really dark ?? this is it ?
System Details: iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz Macbook M2 Pro macOS 14.4.1 Pro Tools 2024.3.1 Logic Pro X Reason 12 UA Apollo 8p Apogee Thunderbridge/Apogee Symphony I/O 2x6 Eleven Rack/Focusrite ISA Two/Onyx 1640i UAD Satellite Quad MOOG Mother 32 Nektar Panorama P1 Axiom AIR 49/Axiom 49/Yamaha P35 Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e Genelec 8040b/Yamaha HS80s/M-Audio BX5a Beats Solo/Shure SRH1840/Slate VMS https://open.spotify.com/artist/7KfV..._branch=1&nd=1 |
NI is not the only one to have a Steinway grand. East west Piano has a very good Steinway Grand, but if you really want to be able to control every single thing up to the fet sound, I suggest you try Galaxy's Vintage-D It's 159 so not that very expensive compared to east West Pianos (full version) but darn is it a powerful and beautifully sounding piano, it even has sustenuto pedaling which I've found that no one else has. I only use Grand piano for quick run down of ideas when I need something to load instantly. Then I switch the sound.
http://www.galaxy-instruments.com/vintage-d.html |
isn't the mini grand good enough ?
#16
As a 27 years and counting pianist myself, no I don't find it good enough. It lacks enormously in the sympathetic harmonics that you get when playing with the sustain pedal. And it just sounds thin compared to the pianos I've mentioned, not withstanding playing on real pianos which I do often, but not as often as I would like on grand pianos
But then again, I'll give you this, it might be enough depending if you're doing pop music, or electro/dance music where the sound of the piano is not as important as in jazz/classical. |
#17
so then you recommend ??
Synthogy Ivory Grand ?
#18
I haven't tested synthogy enough, but Ithink all of these products have trials so I would try them all and see which one you prefer.
#19
Galaxy is one of those that did the Giant Piano for NI which is a cool instrument. |
#20
Ivory does it for me hands down. playing the piano for 30 plus years, it fit my needs jazz,solo, what ever. Depending on your mix or how dense the material you will still have to eq and fit to taste.
Mixing issues for Grand Piano | dan2004 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-29-2011 12:35 PM |
Mini Grand | Sune Lynge Rasmussen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 12-22-2009 10:35 AM |
Mini Grand | shultzee13 | Tips & Tricks | 1 | 05-21-2009 10:12 AM |
Mixing Grand Piano | Riccardo Corbari | Tips & Tricks | 4 | 01-28-2005 11:59 PM |
Mixing Grand Piano | nehemiahmh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 10-28-2004 10:33 PM |
