Old 07-28-2013, 04:03 AM
KingTalkJohn KingTalkJohn is offline
Default Using Air Stereo Width
I'm using Pro Tools LE 8 on the Mbox Mini 2 on my laptop (OS Windows XP) and am attempting an amateurish master of my tracks. I'm using the free plug-in Air Stereo Width to obviously widen my mixes but not dramatically change them. The songs are all acoustic based, containing no more than 10 audio tracks in total. I was wondering if anyone knows of any good settings to use on this plug-in?
Cheers
Old 07-28-2013, 01:52 PM
Default Re: Using Air Stereo Width
Use the setting that sounds the best. Seriously, since this(and all "wideners") work by messing with phase, I would not use it on the entire mix. I use the Waves version(S1 Spacializer), which I like better, and I tend to only use it on these:
reverb tracks
a stereo mix of a lot of BGV's
any bizarre ping-pong type sounds(echo, synth sweeps, sound effects)
Consider, just using harder panning instead of the widener if possible(IOW, maybe its not a good idea to have things all panned near center, then trying to "trick" it into sounding wider than it is. Make it wider in the mix). If your mixes seem too centered, even with a few things panned hard, maybe that's a sign that the track needs some more "stuff", like maybe some percussion(shaker, tambourine, triangle) panned hard to help give the illusion of a wider stereo field.
In any case, check your final mix in mono so you know what happens(good or bad). Knowledge is power(and avoids nasty surprises later)
Old 07-29-2013, 01:32 AM
Amazing answer... Dave, was it? Cheers for that, your post has uncovered a couple of 'holes' in my tracks which I have now filled with tambourines, organs etc... With regards to widening the overall sound, I've scrapped it, sticking with Compression, EQ, Limiter and Dither on my mastering session.
Old 07-29-2013, 11:09 AM
Just remember this; these are not rules, just guidelines. Feel free to bend and break in the name of art And do try the widener on anything and everything. Only you can decide if the final outcome is good or bad(and experimentation(and happy "mistakes" are 2 of the best things about this business)
Old 08-26-2013, 07:36 AM
drumzalicious drumzalicious is offline
I agree with what was posted above. I would refrain from using it on the ENTIRE mix. On your reverbs and delays maybe.
Old 08-30-2013, 10:01 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Originally Posted by albee1952 View Post
Just remember this; these are not rules, just guidelines.,,
Its kinda like the "Pirates Code" then?
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 08-30-2013, 04:21 PM
DJ Hellfire DJ Hellfire is offline
reverb tracks
Agreed!
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 08-30-2013, 04:52 PM
Argggggg
Getting More Stereo Width hebro1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-19-2012 08:11 PM
Group Stereo Width in Stereo AFL Mode pmueller VENUE Live Sound Systems 4 06-05-2009 03:17 AM
Need help with Stereo width... soundfx Tips & Tricks 5 12-13-2006 07:57 AM
Need help with Stereo Width soundfx Post - Surround - Video 1 12-12-2006 08:37 AM
stereo width thin ?????/ Barron Tips & Tricks 1 07-07-2000 09:24 AM
