how to relink from inside pro tools?
When I open a pro tools 10 session that is missing audio files, I get a window labeled "Missing Files" that gives choices as to what to do about the files. If I select "Manually find and relink", I get a window labelled "Relink." Amongst a lot of other stuff, it lists the files that are missing. Is there a way to access this window while in the session? Or otherwise obtain the names of the missing files? So far, I've had to close the session and reopen it, to see that. Thanks for you help, Bruce iMac, Intel Core i3, 3.2 GHz, 4 GB RAM OS X 10.6.8 Mbox Pro, FW800-FW400 adapter cable connection Pro Tools 10; Upgraded to 10.3.2 April 15, 2013 |
Re: how to relink from inside pro tools?
Yep, here is the way - open Project browser (Windows menu, or Alt+O), rught-click there and choose "Relink Selected"
yes. "relink offline" if you need to find it.
Maybe you'd rather choose "select offline" first, in the case you have to 'find all candidates' for instance. abblabla |
Pro Tools 10 missing audio files Relink Problem???? | sebdj | Pro Tools 10 | 5 | 03-13-2014 02:17 PM |
Keep getting error in Pro Tools LE 8! (Help inside) | Lil Eazy-E | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-23-2011 01:37 AM |
Routing inside Pro Tools | Jussi Honka | Tips & Tricks | 6 | 06-14-2008 10:42 AM |
Pro Tools LE System- Missing Audio Files/No Relink | Ericka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-21-2006 04:22 AM |
Running Reason inside Tools LE | juddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-10-2002 10:58 AM |
