Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 04-15-1999, 01:18 PM
fender fender is offline
Default Re: Extentions
I use two Removable SCSI drives, Will taking the extentions out prevent the Drives from mounting?
ZIP[internal]and a SyJet[external]
Thanks Again
Old 04-15-1999, 02:37 PM
Steve Rosenthal Steve Rosenthal is offline
It's a possibility. It's been awhile since I worked with either of those units, so my memory is not clear whether it made a difference or not.
I'd appreciate it if you were able to do a quick test and post your results.
Thanks,
--Steve Rosenthal, Digidesign ETS
Old 04-15-1999, 03:31 PM
results.
I did just that
Both the Zip and the SyJet Mounted and unmounted Fine For now!!!!!!!
I Don't use them For audio.
Old 04-15-1999, 04:36 PM
I did just that
Thanks! I'd say go without the inits until and unless you run into mounting problems.
Old 04-16-1999, 12:01 AM
Default Extentions
>Here's my preferred SCSI setup: Use Apple
>Drive setup on any drive that came from
>apple. Use an FWB that's compatible with your
>OS and PT on anything else. Don't bother
>using any FWB extension or startup
>diagnostics software.
I read this in a post for SCII Crashing
I was wondering if I need to have the FWB Extentions in the system?
They seem to check the ID's of the Drives at startup.
Thanks for the Help this Storage part of the DUC is a very Good idea!!!!!!!
extentions query ^Tripper^ Pro Tools TDM Systems (Mac) 5 01-28-2004 11:57 PM
Mac Extentions HELP mane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-30-2002 05:26 AM
Extentions Manager Mikchek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-23-2002 05:22 AM
optimal extentions settings Dopamine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-24-2000 09:25 PM
MacOs extentions chising Pro Tools TDM Systems (Mac) 3 06-10-2000 08:30 AM
