Slooow startup/loading PT10
I have ridiculously long loading times starting up PT10.
It's actually right when i start it up, the icon bounces in the dock for at least one minute and then the PT10 screen comes up showing "Loading ProTools" and nothing happens for about another 2 minutes before it starts processing the plugins. That last part always goes smooth and quick, loading sessions as well. The weirdest thing is that i'm running the same setup at home just on my MacBook Pro and there's no issues on that. It just flies through the startup/loading process, up and running within 30 seconds. I have not disabled my Wifi or modified DHCP/static IP's at all on my laptop. On the MacPro i only occasionally hook up my iPhone via BT or cable for internet access. All my disks are excluded from Spotlight indexing. Any ideas?? Thanks..
2008 Mac Pro // Dual Intel 2.8Ghz Quad // 8 Gb Ram // Digi 192 IO with HD2
PT 10.3.8 HD // OSX 10.6.8 and 10.8.5 // ProAc Studio 100 monitors // Yamaha P-2200 amp |
Re: Slooow startup/loading PT10
Try the solution referred to in this thread, by BerlinProAudio.
http://duc.avid.com/showthread.php?t=310913
MacPro 2x3GHz Dual-Core Intel Xenon, 19 GB RAM OS 10.7.2, PT 10.0, Digi003 BLA, MC Mix + MC Transport |
Thanks.. I'll give it a try.
However my problem is not what this solution seems to fix since its related to loading sessions slowly. Mine loads superfast when i eventually get to that point. It's the whole process before that up til "loading plugins" which takes forever. Update will follow ofc..
So i tried the BerlinProAudio solution which made no difference.
I also tried to start PT with my expansion chassi disconnected, same thing. The weirdest thing is that i helped out a friend yesterday to install PT10 (native but nonetheless) on her MacPro (10.6.8) which is the exact same as mine and there were no issues at all starting up, it just flies through the whole process. So i did a second install on a fresh partition with 10.6.8 instead of Lion, no additional plugins installed and crossed my fingers But it's the same thing still. Grey hairs are rapidly approaching.. Any ideas anyone???
Nope??
VST not loading in the STARTUP ?? | sebdj | Pro Tools M-Powered (Win) | 3 | 10-03-2008 09:23 PM |
iZotope Ozone not loading on startup | cassettedonkey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-25-2008 05:46 AM |
PT startup - plug-ins loading VERY SLOWLY -help | jlcnyc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-22-2007 11:12 AM |
ilok plugins not loading on startup? | 8trackmac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-23-2006 03:40 PM |
6.1 crash on loading machine control during startup? | prophei | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 07-23-2003 11:41 AM |
